RCA P52939 52" Rear Projection Television Logo
Question about RCA P52939 52" Rear Projection Television
Is there a reset button on rca p52939
Turned it off one nite n it didnt turn on again. when i push power i hear the sound of it turning on but no picture no sound
T.l. Moore
  • 273 Answers
No there is no reset button . you would unplug the set for 5 min's and this will allow a reset . . with the symptoms you give id say you have a shut down issue . the set has detected a error and is putting it into a shut down sequence to protect it self from major damage .
Posted on Jan 07, 2015
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Please Help!
A chirping sound from a TV set is the switch mode power supply trying to start up, but gets shut down because of a major short inside the set or in one of the circuits.. Most likly in this set, the horizontal output transistor is shorted because of a defective flyback transformer. Thats whats the common problem is with this set. A repair like this, if this is the only parts that are bad, will run you about 300 to 400 bucks or so. In some cases, not many but a few times, I have seen poor solder connections on L401 cause the horizontal output transistor to go bad. There are no user replacable parts inside this set, so please play it safe and seek out a pro to assist you in this repair. Good luck PS Please do not forget to rate this thread.
Posted on Dec 11, 2006
Anonymous
SOURCE: MY RCA TVE WONT TURN ON
Did you change your battery from the remote?
Posted on Dec 02, 2007
Anonymous
  • 4234 Answers
SOURCE: is there a reset button for 52in rca hd ready rear projection tv?
Most likely there was one or more marginal connections on the main board and moving the set has completely opened those connections. If you can solder, try resoldering any connections on the boards that appear to be grainy or have rings. Update this with the results. That may resolve the problem. If not, we'll look further into the set for component failures.
Dan
Posted on May 29, 2008
Anonymous
  • 2992 Answers
SOURCE: I have a rca p52939 that won't turn on.
Failure of the HV splitter was a very common problem when I was doing these big screens on the road. The set won't come on if the splitter shorts. We used to test if that was the cause by pulling the HV input lead out of the splitter (leaving it still inside the plastic cup so it wouldn't arc anywhere) and turning the set on. Most often the set would fire right up (without picture of course).
I believe the RCA part number for the splitter is 205064, and it's available from a number of sources. I'm not home right now so I can't check. If I have the number wrong I'll post a follow-up comment.
Posted on Feb 13, 2009
Anonymous
SOURCE: RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Posted on Mar 29, 2009
My ps3 turns on but no picture
First, how are you connecting? RCA jacks(red yellow white cords) or HDMI? If it's the RCA cords, they were known to develope shorts in the yellow cord that connects to your TV. Just try another cord. They are very cheap, and the cords from all of the other Playstations will work for the PS3. Second, try to do a picture reset on your system. Sometimes, going from HDMI, back to the RCA confuses the system because the RCA connections are NOT detected automatically, HDMI is. To do a picture reset, turn the system on, then push the power button once,(you'll hear a beep) then push and hold the power button until the system shuts off.(you should hear 2 beeps) Then when you turn the system back on, the picture will be reset. ^^ Good luck, and I hope this helps.
I unpluged the TV to move it and it will not turn on now. Is the a reset button?
Sometimes the power cords come away from the back of the TV . Mack sure you snug it up or it could be that new out let. Have it tested with a hair dryer or something.
17helpful
1helpful
2answers
RCA P52939 turns on and off by itself
the front buttons are common for going flaky - if you remove the front grill you should be able to unplug them and use the remote only
if you use the buttons let me know and i will look up the board or switch part # all switchs will need to be replaced
thanks
scott
2answers
No response to the remote
check for coolant leak on microprocessor. Coolant leaks from the CRTs.
2answers
Power problem on a RCA big screen TV
Even with the tv turned off, the power supply is still active.It's supplying voltages to the microcontroler, that's why each time you press the power button on remote the tv respond by turning on. First check the power cord to be well connected in the power-bar and if it's ok...well the power supply is defective and due to the high risk of electric shock i suggest you to call a technicien.
P.S. I respond here because I don't know why our chat session got disconected.
5helpful
2answers
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Open Questions:
See all RCA P52939 52" Rear Projection Television Questions
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
