It will not go through a full cycle befor it will pause and needs restarted the code is e11
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
SOURCE: I just had a Frigidaire
hi thanks for the question make sure both water taps to washer are on check that because if the cold water if off it wont go into rinse cycle thanks the appliance doc
SOURCE: FAFW3577KWO washer-code E11
Your machine may have short circuit with the inlet valve since you are facing problem after 5 to 6 mins you are suppose to change the inlet valve
SOURCE: Need directions to remove broken drum vane in a
Open the top of the machine (look behind the top for several screws to remove) and slide it back to release from the cabinet. This should give you access to the screws that hold the vane in place. Hope this helps!
SOURCE: I have a Fridgidaire Affinity
Either you don't have enough water pressure, or the screen filter in the water lines that connect to the machine are clogged.
SOURCE: My Frigidaire washer is reading error code
E11 = Long Fill Time
Check to see the water valves are opened all the way. Check water hose screens for buildup.
I appreciate your post, friend!
Based off the information you have provided your Frigidaire washer, GLTF2940FS1, stopped with 1 minute left in your cycle. This could be a potential issue with your door latch, control board, or a miscommunication within your washer. I would recommend a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. If that does help correct your issue you may need to consult with a technician for proper diagnosis and repair. This may help you avoid any unnecessary part purchases. -Matt
Hey friend, thanks for your inquiry!
I see that your Frigidaire washer, GLTF2940FS1, is stopping multiple times within the cycle. It sounds like a potential issue with your control panel of door latch assembly. You should perform a reset on your appliance by unplugging or flipping the household circuit breaker for ten minutes.
If that does not help correct the issue I would advise you to seek technical assistance from a professional for proper diagnosis and repair. This would help avoid any unnecessary part purchases. Best of luck! -Matt
