Was ran for about five mins without water
SOURCE: My pull cord to my pressure washer is hard to pull
take out the spark plug and trying pulling it , if its still tight then you may have seized your pump ) , put a rag over te spark plug hole as there may be fuel/oil mix in the cylinder , check the oil in the engine , check the oil in the pump ( look for milkey white , if found then your pump back seals have gone )
SOURCE: I have a Briggs and Stratton power washer
Spray well with WD-40 or similar, and take a small chisel, on it's edge, and hit hard enough to allow chisel to dig in to head of screw, making a "V" like slot in the head, then angle chisel slightly and start tapping in direction of loosening(counter clockwise.) Once it loosens enough to get a pair of visegrips attached to head, use them, and spin them out. Make sure you replace them with new screws.
