Question about Lexmark X Office Equipment & Supplies
<!-- from fixya rte -->How do i set the time on a lexmark x464 - X Lexmark Office Equipment & Supplies
Mark Schmit
  • Lexmark Master
  • 1,915 Answers
Usually you need to access the embedded web server on the printer by typing the IP address of the printer into your web browser address bar. This will open a window that will have all the settings available.
Posted on Oct 18, 2014
1 Related Answer
Joed911
JDTec
  • 4338 Answers
SOURCE: I have replaced my photoconductor
Try:
To restore factory defaults:
1. POR the machine into Configuration Mode.
2. Use the down navigation button to scroll to the RESTORE
FACTORY DEFAULTS item on the menu.
3. Press Select. The machine performs a POR.
4. The RESTORE FACTORY DEFAULTS sets the MFP non critical
parameters back to the factory settings.
Note: Some settings are not affected: panel language, energy
conserve, paper prompts, registration margins, and page count.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 20, 2011
How to reset pc counter on lexmark x464
Of course - why didn't I think of holding down 2 and 6 and turn it off and on - that's perfectly logical! Works great but the user interface certainly isn't very intuitive.
Jul 23, 2012 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
I have replaced my photoconductor in my Lexmark x464 and I still have a warning notification comming on. How do I reset it?
Try:
May 20, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Need manual for Lexmark X4530 Printer in order to set up wireless printing via time capsule
HEre it is various including
Lexmark X4530
http://search-manual-online.com/download/manual/Lexmark/aHR0cDovL2xleG1hcmstZW1lYS5jb20vUG9ydHVnYWwvRVBHMDMwOC5wZGY
May 30, 2010 | Lexmark C533DN InkJet Printer
Cannot change/ save two default settings on X6570 Lexmark printer
you can go to printers and faxes (XP) or printers (vista) in control panel Right click on the printer and click on properties. Go to advanced tab and click on printing defaults. It will pop up the printer printing preferences. choose the desired setting. To disable 2-sided printing, go to advanced tab in the preferences window and turn off the feature. Click ok to save all settings. Go back to general tab and click on printing preferences and set desired settings if there is a need. Click ok to save settings. Then, for all changes to take effect, click ok button on the lexmark 6500 series properties window. Try to print again. Hope this helps.
Feb 17, 2010 | Lexmark X6570 InkJet Printer
Reset maintenance counter
To reset the Maintenance counter yiu need to go into Config Mode.
Power on the printer while holding the 2 & the 6 button.
You will see the maintenence counter and can reset it from there.
May 27, 2009 | IBM Infoprint 1570 MFP - multifunction ...
Got x6650 can not get past connect your printer on the setup Cannot get passed the connect printer when setting it up, I have tried more than 10 times to set this damn thing up....
Try this:
- Uninstall everything about Lexmark.
- Delete every Lexmark entry in the Registry.
- Reboot your PC.
- Make sure not to connect the USB cable.
- You need to install the driver first before connecting the cable.
- Instal the driver, make sure your using the right driver. Check Lexmark.com for the latest driver.
- If this does not work, call lexmark.
Feb 22, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Please advise as to how to set the Date and time properly on the lexmark X5470 model --Thanks
You normally set up the time/date in the Fax settings menu. I checked the user's guide and can't find the specific page, but it should be there. Otherwise it can be set by the computer.
Dec 01, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark E232 printer problems in 8.5 x 14 page
Software issue for the printer. Uninstall driver and reinstall. If this does not solve it, it may be time for a new printer. Lexmark printers do not have a long service life.
Jun 23, 2007 | Lexmark E232 Laser Printer
Open Questions:
122 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
