Chances are there is a lose connection to the audio jack. Do it do this when the camera is on a tripod or flat, sturdy surface with no movement? If you are adventurous enough you could find a repair manual online and attempt to open the area where the audio/mic inputs are and check the connectons there. if that's not the issue then it could be in the audio circuts and require professional repair.
You also might try an audio input through the audio line in or aux audio input and see if that stops it.
Testimonial: "Yea. Only the sound is there with nothing plugged in. It could be what u say. I might open it up and lash it with a spanner. Ok thanks."
SOURCE: how can I fix a burn spot on canon video camera xl1s?
It could be a burned pixel. If so you will need to replace the ccd imager block. If it shows up only in the viewfinder and not played back or viewed on a different monitor, then the bad pixel is in the viewfinder. Which you can replace the viewfinder but, if you oinly see it there & not in the final product, save your money &n live with it.
