Question about Kenmore Refrigerators
My Kenmore Elite Trio Fridge is leaking water from under the front of the machine. It is not the water connection. Do you know what the problem might be?
Elite Trio Fridge model number 79578344802. Ice maker in fridge and water in the top left French door.
Posted by Paul Germain on
  • Paul Germain
    Paul Germain Oct 16, 2014
    If the water is off the fridge does not leak at all.
  • Bill Myers
    Bill Myers Oct 17, 2014
    Oh, sorry. I thought you meant it wasn't related at all to the water supply lines.Check the water inlet valves and the john guest fittings.
Bill Myers
    Sergeant:
  • 251 Answers
Your defrost drain tube is probably clogged with ice or something. Defrost your refrigerator (put towels around to soak up any excess water), then after it's defrosted, take off the back, lower panel and look for a 1 inch diameter tube coming down from your refrigerator. Remove it and clear out any blockages and then re-assemble everything.
Posted on Oct 15, 2014
5 Related Answers
Anonymous
  • 109 Answers
SOURCE: kenmore fridge ice maker not working
only two things this could be, either your water valve is bad or your icemaker is bad. you can get a kit which comes with both for a little over a hundred bucks, and you can change them yourself.
Posted on Mar 30, 2008
Anonymous
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
Anonymous
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Kenmore refrigerator (model 106.78187891) leaking inside
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 14, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Frigidaire fridge leaks where ice maker is on
Your leaking problem gives two possibilities. The water control valve for the ice maker side is defective and while shut off the water will continue to slowly flow and leak into the freezer compartment. The other possibility id the condensate defrost drain is blocked and frozen over behind the rear panel of the freezer and at the bottom of th coils. I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Posted on Sep 23, 2009
I installed the water line to our fridge it is a kenm. with out water dispenser all the book says is prime it. how do you do this with no water dispenser?
if line is for the ice maker, with water on loosen fitting on end of line where it is connected to fridge(hold towel under fitting) and re tighten after you see water seeping out.
press the helpful button
Jan 17, 2016 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Elite Trio. What caused it to die suddenly after only six years?
I was going to explain a device called a "defrost timer", but I did a search on your fridge and found the following important information for you to check on FIRST!
CPSC Maytag Corporation Announce Recall of Kenmore Elite Brand TRIO Model...
Info on Recalled LG and Kenmore Elite Trio Three Door Refrigerators
Oct 01, 2015 | Kenmore Refrigerators
We purchases a uses kenmore elite washing machine. When we hooked it up, and put the first load in and turned it on, water sprayed inside and leaked. We imediately unplugged the machine. Now we can
use a t-20 torx or a 7 mm socket to remove the toe kick under the door. then on the right side under the door, reach up inside the front panel find the door lock. at the bottom of the door lock you will feel a flat circular tab. pull the tab about a half inch and PULL ON THE DOOR AT THE SAME TIME.. then start washer and see if you can determine where water is leaking. if you can replace a simple part and repair it, use your model# and do a google search for parts.
May 13, 2012 | Kenmore Elite 45986 Front Load Washer
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Trio
dh means there is a defrost problem with unit you need to repl the controler in evaporator. you will have food loss if not taken care of asap if is under a year old call the tech out there
Oct 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
