Radio Communications Logo
Question about Jabra Radio Communications
Why does my Jabra Easygo headset keep fading in and out during a conversation?
Posted by Lynda Colt on
jim ludwig
    New Friend:
    Problem Solver:
  • 4 Answers
Noise canceling circuitry?
Posted on Oct 15, 2014
Where can I get a user manual?
Hi Robert
See if Jabra Have One.... Search the Internet
You Bought Jabra.... One of the Best... so
They should have support
As in their Video Here
How to pair Jabra BT2045
EasyGo Jabra Headset Bluetooth Android iPhone
1helpful
Why does my headset keeps fading in and out of a conversation?
This tends to happen when the battery is low or your far away from the phone. My Bluetooth ear piece was doing this fully charged, but it was almost 7 years old. So if it is that old then it may be time to replace it.
Jabra easygo driver
http://www.jabra.in/support/support%20for%20your%20product/downloads%20and%20drivers
Online mobile support
some headsets have issues with some phones and work well with other brands find a headset that your phone model recommends
Jabra headset phone
either the switch is partially shorted or the pin on your headet has a shorted wire in it somewhere..try a new headset first..
2answers
How do i pair my jabra easygo to my phone
Hold your blutooth switch on button at few second the light at bluetooth is starts to blink now open bluetooth menu in mobile select pared device and select search new device or go to blutooth menu and select search audio enhancement
1helpful
How do I pair my jabra easygo to my I phone 4s?
Detailed instructions can be found by downloading the user manual from the Jabra support page.
PAIRING IT WITH YOUR PHONE1 Put the headset in pairing mode- When you turn on your Jabra EASYGO for the first time, theheadset will automatically start up in pairing mode, i.e., it isdiscoverable for your phone. When the headset is in pairingmode the Bluetooth status indication on the StatusDisplay isflashing.2 Set your Bluetooth phone to discover the EASYGO- On your iPhone 4s, go to settings>General>Bluetooth and make sure Bluetooth is turned on.3 Your phone will find the Jabra EASYGO- Your phone will find the headset under name Jabra EASYGO.Your phone then asks if you want to pair with the headset.Accept by pressing Yes or OK on the phone. You may beasked to confirm with a passkey or PIN. Then use 0000(4 zeros). Your phone will confirm when pairing is completeand the Bluetooth status indication on the StatusDisplay willshift from flashing light to steady light and the headset voiceguidance will say connected.
Manual pairing modeIf you wish to use the headset with a different phone, or if thepairing process was interrupted, you can manually set the headsetto pairing mode.Make sure the headset is on. Press and hold the answer/end buttonfor approximately 5 seconds until the Bluetooth icon turns froma steady light to a flashing light. Then repeat steps 2 and 3 in theabove pairing guide.Connecting with your phonePairing is only needed the first time a headset and phone areused together. When the headset and phone have been pairedonce, they will automatically connect when the headset is on andBluetooth is activated on the phone. The headset can be usedwhen it is connected to the phone. If the devices are paired, butdo not immediately connect, tap the answer/end button. Whenyour headset is connected the Bluetooth connection icon in theSTATUSDISPLAY WILL BE CONSTANT ON FOR 3 SECONDS andthe headset voice guidance will say connected.
Feb 19, 2012 • iPhone Apps
1helpful
2answers
Where do I get the passkey to pair with my phone.
the passkey is 0000 you can find all of the quick start information at this link:
http://www.jabra.com/sites/mobile/ap-en/products/pages/jabraeasygo.aspx
thank you,
Lee
2helpful
First time pairing to bb9530 storm to jabra easy go doesn't work
You could try to force your headset into the pairing mode. In order to do it, with it turned on, press and hold the answer/end button for some 5 seconds, until the bluetooth indicator light is rapidly flashing. It is in pairing mode now. Then, withing the next couple of minutes, bring your phone close to your headset, and make its bluetooth application search for new devices. After a little while, your headset should appear on your phone' screen. Select it and command it to connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset will enter the stand-by mode. There could be an indication on your phone too, that a headset is connected.
Hope you are able to sort your problems out soon.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
1helpful
The Jabra A210 keeps dropping the connection between the devices.
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
Top Jabra Radio Communications Experts
David Shaub
 Grubhead
Grubhead
Marvin
Marvin
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
