Question about Panasonic VIERA TC-P55ST50 55 in. 3D Plasma HDTV
How do I calibrate my Panasonic TC-P55ST50 for the best picture quality?
On factory settings now. Looking for the best way to calibrate so I get accurate colors for movies and TV.
Posted by Justin Mears on
Tom Chichester
    Top Expert:
  • Panasonic Master
  • 57,273 Answers
Tweak the factory default settings until you are satisfied with the results.
Posted on Oct 15, 2014
5 Related Answers
Anonymous
SOURCE: Panasonic TH-50PX60U Plasma TV no red color
I had the exact same problem. Thought it was the tv, but it was the cable between my cable box and the tv. Try unplugging the cords and plugging them back in, color was restored.
Posted on Oct 17, 2008
Anonymous
SOURCE: Can I set up tv remote to also control cable box?
Just bought a Vizio 22" 1080 p TV and need to set up a Verizon Fios remote for it. The codes for Vizio for the remote do not work. Can anyone help me with this.
Steve
Posted on Jan 14, 2009
Anonymous
  • 9 Answers
SOURCE: calibration for a new lcd hdtv
yuo sound like you are watching analoque tv press the tv button on remote for digital
Posted on Mar 11, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: i am just looking for
There is not a listing - because every set will be different.
You need a calibration DVD to get the optimum settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 08, 2010
Azrael SRL
  • 11800 Answers
SOURCE: what is the optimal settings
There aren't any - the adjustment should be done just as you like. This page http://reviews.cnet.com/4520-6463_7-5085739-2.html shows the proper steps in adjusting it.
Posted on Sep 25, 2010
On HDMI settings,how to use cc
Unfortunately, the HDMI standard does not carry the CC digital information, for any TV to decode and display it on its own. Therefore, when watching HDMI source the CC button on the TV's own remote, cannot work.
However, each Cable, Satellite or Internet streaming device can decode the CC information from the source (when available). Then the CC text is inserted into the picture and sent to the TV via HDMI or any other video connection.
Look for CC option on your Cable's or Satellite's remote control, or on the source device's menus.
Feb 17, 2016 | Panasonic VIERA TC-P55ST50 55 in. 3D...
Can I use a Bluetooth adapter with this set?
This VIERA model does not include Bluetooth. You CANNOT use a Bluetooth adapter with it via the TV's USB port, because the TV does not have the internal software to work with your adapter. It's a TV, not a computer!
Dec 28, 2015 | Panasonic VIERA TC-P55ST50 55 in. 3D...
I have a tc-p55st50 panasonic television that will not power on.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time; especially to Plasma TVs.
Sep 24, 2014 | Panasonic Televison & Video
Best picture settings for Panasonic tc-40a420u
Enter in picture setting and select VIVID and the format in 16:9
Sep 07, 2014 | Televison & Video
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Jul 04, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
TC-P55ST50 problems with netflix loading
You might be dealing with a bad Main Board ( the board with all the inputs on it) you would need to replace it. You can find the part here
Jul 18, 2012 | Panasonic Televison & Video
What is the proper calibration settings for a panasonic tc-p50s2n. I have used it for over a 100 hours
Do you have access to a test pattern or color bar ? .If you have a THX certified DVD ( some Walt Disney movies ) it will have calibration setup guide in the DVD menu.Or else you have to buy a calibration DVD if you are serious about your TV setup.
First you have to set the contrast and brightness using the Grey-scale pattern. Seven set of vertical bars slowly progressing from white to black. If set right you should be able to make out all the seven bars with out each merging ( or overlapping ) into the other. You will be able to see the line of demarcation between each vertical bars. Then set the color to taste.
If you do not want to purchase the above mentioned DVD disc a close setup figure for your Panasonic TV would be
Picture Mode = Standard ( Normal )
Picture ( Contrast ) ---- 50
Brightness ---------------- 50
Color ------------------------ 33
Sharpness ---------------- 50
Hue ------------------------- In the middle
This setting should give you a decent picture quality assuming your TV is new.
Apr 12, 2011 | Panasonic Televison & Video
I am just looking for the best custom settings for my 42" Panasonic TC-P42C2 Flat Screen TV. Is there already a list of custom specs out there?
Sep 08, 2010 | Panasonic TCP42C2 42 in TV
Hi I have purchased a Panasonic TX 37 LZD80. It is 1080p and has a built in freeview. The tv came with the usual factory settings but the image quality looks dire - it was a considered purchase after much...
Hi, the best thing to do is do a factory reset check your manual for details on doing this. if this does not work i would advise taking the set back to where you got it and they should replace the set for you
Mar 11, 2009 | Panasonic TX37LZD80 37 in. LCD TV TV/HD...
Panasonic VIERA TC-P55ST50 55 in. 3D Plasma HDTV Logo
365 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
