Question about Samsung HLT6187SAX 61" DLP HDTV
I own a 61inch samsung dlp. The problem i've been having is the picture not showing when it comes on which it rarely does no matter how many times i hit the power button. When it does come on
I own a 61inch samsung dlp. The problem i've been having is the picture not showing when it comes on which it rarely does no matter how many times i hit the power button. When it does come on the picture color is wrong and very dim. Then sometimes only the audio can be heard with a black picture.
5 Related Answers
ahhsoo69
MICHAEL WALLACE
  • 167 Answers
SOURCE: HLN507W Samsung 50" DLP
hello yes it sound's like your fly back transformer is going bad. to me.!!! just have to wait and see. wont take long if it's doing what you say. "hope this help's you "good luck"
Posted on Aug 20, 2008
Anonymous
  • 146 Answers
SOURCE: Samsung HL S5088W picture issue
I would replace the lamp. A lamp can come and go as one of its problems of being bad.
Posted on Nov 20, 2008
Anonymous
  • 240 Answers
SOURCE: Samsung HL-P6163W DLP sometimes turns on with NO PICTURE
sounds like the dmv pcb bpard cost 597.70 and about a 250 core charge from andrews electronics.
or you can look ay the price at partsstore dot com.
regards,
daniel.
Posted on Jan 11, 2009
Anonymous
  • 14 Answers
SOURCE: My Samsung HLP4663WX has no picture, can't power off
it may be a bad DMD board. This is usually the problem when you get the three lights of death.
Posted on Sep 17, 2009
Anonymous
  • 39 Answers
SOURCE: Screen went B&W and I hear a loud humming noise from the TV...
Hi John,
If you are hearing this noises,that's your Color Wheel.
The reason fot that is because your color wheel spins 5000rpms(revolution per minute) and something that modifies the balance if the disc can cause different things.Unfortunately in order to check if your color wheel is working properly you need to open your TV and physically check out.
Grinding= Most probably the color disc is broken and you need to replace it.
Spinning / Buzzing = The bearing of the wheel is loose and is loosing its balance,eventually it will brake.
The best thing to do is to take the color wheel out and spin it ,if you feel that the disc kind of wobbles or doesn't spin smoothly you have to replace it.
You can check DM they have very good prices
http://www.discount-merchant.com/SearchResults.asp?Search=samsung%20color%20whee l?click=52978
I hope this will help,please keep us posted
Posted on Oct 05, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
My Samsung DLP is each day getting more and more white spots. Please help me
The dlp chip is bad and will need replacement to fix the white dot issue.
Dec 13, 2012 | Televison & Video
NUMBER 3 FAN WARNING ON SCREEN THEN TV SHUTS OFF SAMSUNG 61INCH DLP
It could be that the bulb/fan unit has come unseated inside the TV. If you want to attempt this repair yourself this is a good reference:
http://forums.cnet.com/7723-13973_102-321561.html
You may need a new lamp unit but the same instructions would also allow you to install a new one.
Jun 27, 2011 | Televison & Video
Samsung dlp 61inch light engine
Most of the DLP parts suppliers are selling the entire light engine assembly complete with the color wheel also. Most places start about $400.00. I don't recommend doing this because of the reliability factor with DLP sets are not the best.
Nov 30, 2010 | Televison & Video
The Samsung DLP temp light stays on, not blinking.
Tries unplug & replug after 10-20 mins see what happen.This prob.show up indecated ur BD power board might die soon.Alot power light,stanby blinks power board it dead.Probally this symtems show up alot people just don't pay attention to it.
Sep 03, 2009 | Samsung DLP HL-P5663W 56" TV
My samsung dlp 61inch dont have any power on it.Is there an automatic shut off switch in the back panel? This had happen after I replaced my colorwheel.I dont have a manual for this tv.
did you replace the color wheel yourself? if so, it's a good possibility that something came unplugged or wasn't plugged back in correctly. retrace your steps.
Jul 31, 2009 | Samsung HLP6163W 61" Rear Projection...
I have a 61" samsung dlp. It worked fine
Start with replacing the lamp. Then move on to the Ballast. Then the color wheel. Then the Power Supply. One of those parts should fix it. If not call back.
Jul 15, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HLT6187SAX 61" DLP HDTV Logo
60 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
