Question about Casio Exilim EX-Z750 Digital Camera
My camera won't go on when I press the on button. It is fully charged - the green light on my cradle is on when I try to charge the camera. How do I get the camera to go on?
5 Related Answers
Misty Hoffman
  • 374 Answers
SOURCE: Battery Charging Problem
First of all I would make sure that the battery is in correctly. There should be an arrow on the battery that should line up with a plus sign on the battery door. Once the battery is installed correctly then place the camera on the charger and the light should be a solid red. If that still doesn't work then I would be more inclined to think that you may have a defective charger. I would call Casio repairs and see what they can do to help you.
Posted on Jul 17, 2007
Anonymous
SOURCE: Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Posted on Dec 13, 2007
Anonymous
SOURCE: myCasio exilim 2.0 won't charge!
Juat wondering if you have a casio exilim ex-s2 that you would want to sell for parts? Or if you know anyone that has one?
[email protected] please let me know
Posted on Apr 05, 2008
Anonymous
SOURCE: casio Exilim EX-S770
Hey I just tried the banging solution to my EX S770 and it really worked. I did not use the compressed air blow part but I did bang the camera on the bottom on the granite counter top and it working fine. Thanks!
Posted on Nov 25, 2008
Anonymous
  • 477 Answers
SOURCE: Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at [email protected]
Posted on Mar 05, 2009
Won turn fully charged battery
You sure your battery is fully charged and still good?
on the other hand Sony Cyber-shot's are known to have this problem.
Try pressing the on button for 5sec
Nov 24, 2017 | Sony Cyber-Shot DSC-WX9 Digital Camera
How do i know when my coolpixs3000 is fuly charged?
The battery is fully charged when the charge lamp on the back just under the shutter releaes button stops blinking green and goes off.
Apr 20, 2010 | Nikon Coolpix S3000 Digital Camera
On a vector jump start system, does the green light have to stay on to indicate that is charged> what if only the 2-3 red light go on when i press the test button?, when the green is flashing while...
2 - 3 red lights indicate not fully charged. Green light = fully charged.
Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
Thanks for posting at FixYa.com
Dec 13, 2009 | JUMP START SYSTEM
My casio ex s880 won't turn on. when i put it on the charger cradle the red light flashes (it normally doesn't flash). Also when its on the charger it'll let me view my pictures on my memory card it just...
It happened to me. I fixed it by luck . Here is my way . fully charge the camera till the led turns green. "IMPORTANT" unplug the power of the charger first, then remove the camera from the cradle . Then I pressed power button, it worked.
Wish good luck to you too
cz
Jul 18, 2009 | Casio Exilim EX-S880 Digital Camera
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Samsung NV10 Charging problem
I had the same problem while charging the camera with the cradle. I tried charging directly with the camera and it looks good. Problem seems to come from the cradle itself. Phil
Oct 24, 2008 | Samsung NV10 Digital Camera
MyCasio exilim 2.0 won't charge!
Feb 14, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Camera not charging.
hi, its underwarranty you my return it and they will find a solution.
Dec 25, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Casio Exilim EX-Z750 Digital Camera Logo
61 people viewed this question
Top Casio Cameras Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
