Question about Canon Office Equipment & Supplies
What does the Canon IR8500 error code E000222-0000 means?
Image Runner IR8500 Error Code E000222-0000
Milan Hrncic
    Champion:
  • Canon Expert
  • 234 Answers
There's no code like that in my manual.It's220-001 means lamp inverter PCB faulty,or reader controller PCB faulty. There's also a E 225-000 error which mean scanning lamp(xenon tube) is faulty,or inverter or CCD
Posted on Nov 26, 2014
5 Related Answers
Anonymous
SOURCE: IR8500 giving E000830-0000 Error code
Having trouble with my IR8500 getting Error code E000218-0000. Any Suggestions? Thanks
Posted on Apr 04, 2008
Anonymous
  • 67 Answers
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
Posted on Aug 19, 2008
Anonymous
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
Posted on Oct 15, 2008
1234567890mi
  • 58 Answers
SOURCE: ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Posted on Aug 07, 2009
57 varieties
Karl Wright
  • 1653 Answers
SOURCE: canon image runner error code E000000-0000
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Posted on Oct 13, 2009
Canon image Runner 2202 error code E000-0000
Aynalem, Canon image Runner 2202 error code E000-0000
2helpful
2answers
What does error E000003-0002 mean
The error code means you have a fixing unit problem. I take it you have a Canon machine. It may be rest, but whats the model of the copier? There are to many different models and ways to rest the code.
129helpful
5answers
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
3helpful
2answers
Canon Image runner 3200 error code E000002-0102
press *28*
<functions>
press "clear"
"error"
<Ok>
then off the main unit and on it
1helpful
2answers
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
20helpful
3answers
old marine
old marine
Ekse
