Question about Canon PIXMA MP495 InkJet Printer
How do I stop my Canon PIXMA MP495 series printer from squeaking when I print?
The printer squeaks loudly when I print how can I fix this issue?
5 Related Answers
pineworks
Clive
  • 4345 Answers
SOURCE: Canon MP600 Printer - How do I fix error code 5100
Hi Whitey621
Error code 5100 Try
Solution 1:
Look inside for a tiny object like a piece of paper, a staple...
Solution 2:
There is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.
Gently clean this strip with a damp lint-free tissue
Hope It Helps: Pineworks.
Posted on Jan 27, 2010
ikkenom
  • 10406 Answers
SOURCE: how to install a canon pixma mp495 printer with no
CANON puts its device-drivers onto its web-site: http://www.canon.com
Click "Support" or "Downloads".
Enter your model-number.
Select your Operating System.
Download the device-driver.
Install it.
Print.
Posted on Feb 01, 2011
Testimonial: "You guys are awesome thanks"
yaoyang
  • 2340 Answers
SOURCE: Where can i find the serial mumber on my canon
PIXMA Printers and All-In-Ones
The serial number is located inside your PIXMA printer. To find it, open the printer lid as if you were to access the cartridges tray: the serial number is printed on a white sticker. Be careful to not confuse this number with the power supply serial number that can be found on the bottom of your printer.
Hope it helps.
Posted on Apr 26, 2011
lapoljo
SOURCE: Canon PIXMA MP495 Error Code
Hi Taco
I have the same problem. Did you find a solution?
Posted on May 28, 2011
Helpster2
SOURCE: Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
Posted on Dec 11, 2011
How do I find ip address for canon pixma mp 495 printer?
Two links for you
Pixma MP495 Printer not detected - Canon Community
community.usa.canon.com/t5/Printer-Multifunction.../Pixma-MP495-Printer.../25583
  1. Cached
  2. Similar
May 26, 2013 - So I have a Canon Pixma 495 printer that worked great wirelessly ... Hi I have the Canon Pixma MP495 and I can't seem to find the IP address.
PIXMA MP495 Wireless Connection Setup Guide - Canon Europe
www.canon-europe.com/.../pixma_printer.../mp495_printer_wireless_connection_set...
  1. Cached
  2. Similar
This method is by far the easiest way of connecting your PIXMA MP495, so if your ... Press and hold the [Maintenance] button (A) on the printer for approximately 5 ... regarding pressing the WPS button, please refer to the access point manual.
ip address for canon pixma mp 495 printer Google Search
Oct 04, 2016 | Canon PIXMA MP495 InkJet Printer
CAN I PRINT WITHOUT A COLOUR CARTRIDGE ON CANON PIXMA
regarding your question, the printer is designed to work on two cartridges.. if you want to print black and your printer has a depleted colored cartridge, you can reset the level of you ink via long pressing the red button (stop/reset). hope to be of help.
Jun 20, 2014 | Canon PIXMA MP495 InkJet Printer
Tried pushing the comcast router WPS button to set it with the printer, but its not working. help
Hi there :first your router must be " A commercial access point or router that supports IEEE802.11b/g/n is required. "You have to do the installation two times , folow this link :http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP495.aspx?faqtcmuri=tcm:14-774514&page=1&type=faq
I hope this information will help you.
Nov 30, 2011 | Canon PIXMA MP495 InkJet Printer
Nov 22, 2011 | Canon PIXMA MP495 InkJet Printer
Canon PIXMA MP495 InkJet Printererror code 5200 problems
Here what I found for you. If it fixes your issue, don't forget to give me a good rate. Thanks
Print head temperature rise error or Error Code 5200
Condition: The print head temperature exceeded the specified value.
Problems and Solutions:
  • Turn off the printer and then turn on if error still persist replace Ink cartridge or print head thankyou for using
Aug 30, 2011 | Canon PIXMA MP495 InkJet Printer
My printer is squeaking very loudly whenever it
Take it apart, and clean and lube the components.
Oct 14, 2009 | Lexmark C532dn Laser Printer
Pixma Pro 9000 Canon Printer is printing terribly colored photos.
HOW LONG HAS YOUR INK SAT IN THE PRINTER WITH OUT USE AND IS IT A CHEAP INK THAT YOUR USEING ? IF SO THAT COULD BE THE PROBLEM
Apr 05, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
Canon PIXMA MP495 InkJet Printer Logo
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
