To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
Turn on your
- Mobile phone
- Vehicle
- Radio/SYNC
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the
Phone button to access the Phone Menu. Press
OK. Add a Device displays. Press
OK.
SYNC prompts, "Press OK to begin pairing device." Press
OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press
OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the
Arrows to select the Exit message and press
OK to leave the Phone menu.
