Question about NorStar T7316E Corded Phone
<!-- from fixya rte -->How do I change name of employee - NorStar T7316E Corded Phone
2 Related Answers
Anonymous
SOURCE: Trying to change the name on a phone
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4
3.Press the top grey button (the set on the lower right hand side with the grey buttons closest together)
4. press the button under the one you just pushed until you get the desired name/ or the one with no name
5.press the same button as in number 3 (once only)
6.press the same button as in number 4 (2 times) you should get the name and a soft key button for change
7.type the name like a text message
8. once you filled it in hit the same button as in number 4.
9. hit release
Posted on Oct 25, 2008
Anonymous
SOURCE: changing employee name on extension
http://www.phonserv.com/1_m7310_phone_meridian_norstar_phone_system.htm
This has PDF file that will give instructions.
Also this link has more instructions:
http://www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_systems.htm
To Change the Name on a Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number (extension. you want to change the name on
5. The display shows "Reset Password"
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Posted on Mar 10, 2009
How do you change employee's name on phone
Go into phone numbers go to my number and choose reset input your number again and replace new name please give thumbs up thanks
Aug 09, 2011 | Toshiba DKT-3220-SD Corded Phone
Voice mail display & retreving messages
Do you know how to get into phone system programming? The extension names are changed in there.
Mar 10, 2010 | NorStar M7310 Corded Phone
How do i change didplay name on extention for nortel network T7208. i am a new employee and i realy want to change the previous employees name
If you have a 7310 set in the office use that phone to program.Dial feature **23646 PWSD 23646 or 266344 Tap the right bottom button until you see name displayed on the lcd screen.tap top right it will say ext Number dial your exttension number (if you don't know rls from program and dial Feature*0 and tap your INtercom key) once your number is in tap top right until you see name tap sofkey change and dial in your name A=2 B=22 C=222
Jan 20, 2010 | Lands Phones
We have a new employee. How do I change the name on "image send" to the new employee?
I am assuming you have sharpdesk or network scanner tool installed on the computer you are wanting to send a scan to.
Click on start then programs and look for sharpdesk/network scanner tool and start the NST program. Once it is open/started you should be in the "profiles" tab and there should be some profiles listed (presumably the old employees name). Put a check mark next to the ones you want to delete and click delete. this will remove them from the copiers image send. Then create a new profile (add) with the new employees name and apply the changes. Restart the copier and the employees name should show up.
Mar 25, 2009 | Sharp AR-M355N Copier
How can I change the name on the display of the Toshiba phone? We have a new employee and still list the old employees name on her display.
By dialing intercom #621 and pressing the * key to move cursor left. press pound changes to letters and 0 is toggle. Your manual and good guides are here
http://guides.idacomusa.com/
Feb 26, 2009 | Toshiba DKT-2010H Corded Phone
Display Names
Hi....go to www.phonserv.com and you will find the answers to just about all your questions for this phone....I could send you a copy of mine if you like just send me your email or go to the site yourself and print one...its very handy....
Nov 24, 2008 | NorStar T7316E Corded Phone
9. hit release
Oct 06, 2008 | NorStar T7316E Corded Phone
Help
You needs to enter to a program mode inside the PBX option.
the name Its inside the PBX.
Once you on the Extension 101 enter program mode press choose program 004 select the station number and put the new employee`s name.
Jul 11, 2008 | Panasonic KX-T7630 Corded Phone
Change the Extension ID To New Employee Name
To change the names on the NEC Dterm 80.
Feature, Conf, #, 0, *, 8974, LINE 4, 18.
Select Conf to go to the name you want to change.
Select Hold to erase the characters.
Select Transfer to save it.
Once you save, make sure you go back to "18".
Mar 11, 2008 | NEC DTU 8D-2 Corded Phone
HOW TO CHANGE NAME ON THE EXTENTION LINE
You will have to go into system programming. If you are not familiar with it, you will need to call in a professional, as it is too hard to explain over posting.
Dec 29, 2007 | NorStar M7208 Corded Phone
NorStar T7316E Corded Phone Logo
80 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
