SOURCE: whirpool duet front load washer door trouble
I have stacked ours too, though after 5 years we have not had any issues with the pressure. I would suggest checking the screws holding the hinge in place as they may have loosened or been tightened with the door not properly lined up.
SOURCE: Can I stack them easily? Do I need any accessories?
yes you need the stack kit. you can buy it a sears or any local appliance parts store. youll need to have to model number of the washer with you so youll get the right one
SOURCE: Can the Whirlpool Duets stack?
The simple, short answer is yes, the Whirlpool Duet washer and dryers can be stacked. You'll need to check with the Whirlpool folks to see if you'll need a stacking kit, or if they are ready to go with what you already have.
The key to stacking these Duet laundry pairs, is to have both the washer and dryer model numbers when you contact Whirlpool, so they can provide you with the stacking kit needed to mount the dryer on top of the washer. You can also check the Whirlpool web site to get a good idea of how much space is needed for a stacked set. Here's the link for the space checker, just look under the Guides and Tools on the left side and click on the Laundry Space Sizer to see what's needed.
http://www.whirlpool.com/catalog/category.jsp?cat=115
You can also call Whirlpool at (866) 698-2538 and speak to them about your particular washer and dryer.
Hope you find this Very Helpful and best regards!
SOURCE: My Thin Twin Whirlpool stacked washer/dryer has a
You can do it yourself, them supports are pricey, your repair manual is HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Whirlpool thin twin stacked,won't agitate or spin
whirlpool washers have a drive coupling in between the motor and the transmission to replace this remove the top and disconnect the lid switch set it aside remove the front panel then remove the 2 clips that hold the pump on then push it out of the way then remove the 2 screws that hold the motor clamps on and then remove the upper and lower motor clamps remove the motor then replace the three piece "motor coupling" one piece goes on the motor the other three pronged plastic piece goes on the transmission and the rubber isolator goes between them and now just put every thing back together
