Cars & Trucks Logo
Posted on Jul 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front electric windows have droped slightly and do not shut on the rubbers correctly
Anonymous
Level 3:
President:
  • Master 2,187 Answers
  • Posted on Jul 05, 2009
Anonymous
Master
Level 3:
President:
Answers
2187
Questions
0
Helped
559369
Points
6379
This normally happens to older cars. Check if the mechanical in the door has gone loose or lost alignment. Normally they should be following the rubber surrounding the door's frame. Also check on the gears if it is aligning with each other. While at it check if the rubber on the door frame needs replacing.
The electric windows and door locks only work on drivers side of a 2000 buick le sabre limited. why?
The passenger side locks an windows don't work with thier own switches ? Check for B+ voltage at the front passenger door module . Do you know how to do that ? You need to take the front right door panel off . Check for a broken wire inside the rubber boot from the body to the door .
Power Windows
The vehicle is equipped with power windows controlled by the door modules. The DDM receives a window switch request, over the SBI serial data, from either the passenger door module wired to the window switch pressed or from the driver door switch assembly. The DDM checks the Class 2 serial data to see if the status information is correct (i.e. ignition switch position) to permit window operation.
If the status information to permit window operation is correct, the DDM sends the command to the door module controlling the window to move the window as requested.
1999mAZDA 626 drivers window stuck half way.any suggestions
If It Is Electric Turn Key On Hold Button In Up Position While Thumping In Inside Of Door Below And Slightly Forward Of Center Of Armrest-----This Is Not A Forever Fix--Brushes Bad In Window Motor-And Motor Has To Be Replaced. Once Up, DO NOT USE Until Replacement. Note: Use Rubber Hammer Or Side Of Fist--Using Other Things Will Damage Door Panel.
What torque specs do u tighten the front shock absorbers nuts to
adjust the nuts until there is tension placed on the rubbers. You will see the rubber start to slightly bulge out under the washers and that will be the correct tension
The driver's window on my 93 honda civic 1.5 Lsi is not closing properly. The motor works fine but the window slants and does not go into the rubber. The rubber is slightly buckled at the front panel is...
What you need to do first is remove your inner door panel. After you have the panel removed operate the window and make sure that none of the window tracks are loose, broken, or out of adjustment. This is your most likely cause of your problem. A slight buckle in the panel may help the problem but, I don't think it is your main problem. Check the tracks and adjustments.
Change light bulb on 2008 foucs
the uk focus need head lamp unit to be unbolted 2 bolts at top, the unit is then carfully pulled forward when u feel the clips release, the unit needs to be slightly lifted up and out with out droping it, to install you have to put in recess lower pull to front slightly then when drops down push back and into clips , bolt back up.if you are in uk halfords charge £6.99 to do this for you,
Lost power to power windows, door locks and sun roof.. I can not find the correct fuse that i think has blown. I have looked everywhere and all of the fuses are just fine.. 1992 Toyota Camry V6 XLE
Most likely a broken wire in the harness from front drivers door...open up and cut off the rubber boot and fix broken wires...they tend to break after a few thousand opens and closes...then wrap with electrical tape to replace the rubber boot...Lee
Runs and drive for 1 mile then dies
hi same deal as the other guy but yours is slightly differant your computer will shut down when the voltage dropes below 7 volts or above 14 if the battery is going flat it will recover when left for a while if it has plenty of charge it maybe overcharging and again it will shut downget the voltage reg/charge rate checked first
good luck regards ray w QLD OZ
Back passenger side electric window droped completly.
replace window regulator, these are expensive from the dealer, but most are available used are after market
FRONT DOOR WINDOW
Yes. I have fixed my driver side window several times. The window went all the way down and came off the track, usually because the window automatically went all the way down. The first step was to take the interior side of the door off: (1) I unscrewed the screws around the door and pull the plastic screws out. (2) I disconnected the thin metal rod that connects the door handle to the door frame to be able to pull the interior part of the door away from the metal frame of the door. (3) I unscrewed the speaker to see where the window meets the rubber track. (4) I kept the electrical wires connected so that I could use the electric window button to lower and raise the window. (5) I lowered the window down below the rubber track and loosened the screw holding the rubber track to the door. (6) I manually adjusted the rubber track around the window glass and pressed the electric window button up slowly, making sure the glass stayed on the track. (7) I put everything back in place, screwed in the screws, etc. Be careful not to let the window go all the way down, because it seems to fall off the track at that point. Hope this helps!
Door window
this is a common problem with the accord what happens is the window starts sticking in the window rubber one one side more than the other and bends the arms on the window mechecanism you can bend these back and take the window rubbers out of its frame clean them put them back spray them well with wd spray but the problem is are you feeling lucky as the perminant souloution to the proble is to replace the window rubber and window regulator is the name of arms on the window mechecanism if you intend to replace its not as bad a job as you think all wires on your door pad are plugs so you cannot go wrong as far as the regulator it amatter of about half a dozen nuts yates210456
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
