This means that the laser unit inside your printer has failed. It costs around 100 dollars for the part and it needs to be installed by a trained technician. Best idea is to buy another printer. Sorry.
This error on the Canon iPF-605 wide format printer means that there is a problem with the paper cutting knife. The knife (black block) should be at the left front side in it's rest position.
Powered the printer down and moved the knife block from right to left, powered on and voila: problem solved ! Thanks Canon support!
Try partial reset and semi full reset of the printer, this is error message is a hardware error, if the issue is still not resolved contact HP, they would replace the printer if it is under warranty.
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name).Un-intall printer and printer software completely.Go to manufacturers website and navigate to their drivers/downloads or support menu.Select your model, choose the relevant software and download to the new folder you created on your desktop.Power down your computer.Reconnect the printer to the computer and turn printer on.Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files.Direct the wizard to your new software, follow the rest of the setup instructions and your done
Here is a link to the error code that you are receiving and it includes a troubleshoot.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=true&docid=3448BE8E41616B39E040A68F5B28300D&journalid=18CBB4A8572211DCAEB7A5F38B3D0A57&l=en&s=dhs
Hope this helps:)
Jason
