HP Officejet 6500A Plus Logo
A
Anonymous Posted on Oct 14, 2014
I have put in a new black hp cartridge,blue, red and yellow are working but black will not print
Len Dipper
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 136 Answers
  • Posted on Oct 14, 2014
Len Dipper
Expert
Level 2:
Night Owl:
Answers
136
Questions
Helped
29462
Points
191
Is the new cartridge identical to the original?,some require that a small circuit board be transferred to the new cartridge from the old...
Len...
I am still not able to resolve the error message below after trying suggested solutions. I might add that my printer is not used frequently. Could it be damaged beyond repair because of this? Getting...
Hi, do note that even if you are printing in black, the printer requires that you have installed functioning cyan (blueish), magenta (reddish) and yellow cartridges as well.
Printer is printing yellow instead of red and colour is fade
The magenta has run out (red).
Replace the HP 22 tri-color cartridge.
It probably has yellow and cyan (blue) left in it, and the black is most likely working as well, but if any of the 3 colors in the tricolor cartridge run out, the whole cartridge must be replaced.
For instance, if I printed my vacation photos and there was a lot of water and blue sky in all of them, the cyan might run out long before the cartridge life expectancy.
Also, don't forget that cartridges are rated in pages printed at 5% coverage.
Since a photo is about 25% of a full page, a photo printed at full bleed (edge to edge) will only yield 32 4 X 6 inch photos from a cartridge rated at 160 pages (5X expected coverage = 1/5 the prints)
I have HP Deskjet D2466 Printer and when i want to print with color cartridge, the black color would be printed as blue color... My black cartridge was exhausted so i only can printed with color...
when the color cartridge has to make black, it uses all three colors. printing blue indicates that the color cart. is getting low on red and yellow. get a new black cart. and a new color, 'cause it' s coming due.
Let me know
No red
the color red is a mix of two color. so run the cleaning tool on the printer
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
1helpful
Black ink won't print
check printer preferences and settings.
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Black or Blue not printing - just red and yellow
Are you using geninue Microboards new cartidges or refills? If you are using the new Microboards ink carts, then you have a bad cartridge, or possibly a bad batch. Simply call Microboards tech support at 952.556.1639.
http://www.techwaredist.com
2helpful
2answers
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
k24674
Grand Canyon Tech
Grand Canyon Tech
