I have a HP32S II scientific calculater. Display of the same is very faint, would like to darken it.
SOURCE: The display is coming very faint
Most probably the batteries since I just had the same exact problem and replaced them. Works like a charm now. Takes two batteries. A76R W82.
SOURCE: Trying to get calculator to display in scientific notation
Press the [SHIFT][MODE] to access the (SETUP) screen. -See the screen capture below. Press [7:Sci] to select the output display format to be Scientific.
You will then be prompted to key in a number between 0 and 9 to choose the number of decimal digits.
If you do not want fractions nor radicals set the default Input/Output format to LineIO.
To do so press [SHIFT][MODE][2:LineIO]. After that perform the steps given above to select Scientific format for the output.
