Question about HP Photosmart C7280 All-in-One Printer
Pump motor stalls in my HP printer
The pump motor stalls and I am unable to print. The machine makes awful noises.
Bob Buchholz
    Scholar:
  • 136 Answers
When an inkjet printer is making "awful noises" it means that there is either a paper jam or the carriage can't move properly. Remove all paper and check for a paper jam - if this is not the problem, turn off the printer and see if you can move the print cartridge carrier by hand. If it is hard to move, clean the shiny carriage rod with a cloth and put just a drop of light oil on it. Move the carriage back and forth and clean it again - repeat until it moves easily and add a final drop of oil to the rod.
Posted on Oct 14, 2014
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: Pump motor stalled
Try this I have had machine similar apart On the left hand side (Facing the printer) behind side cover sits a micro pump for the ink. Pull cover and check that belt is OK from gear to micro pump. You should be able to just turn back and forth- not too much, the large pulley on the pump. There will be some friction here..... I think you can turn on machine OK with this cover off and see if pulley is turning
Posted on Apr 24, 2009
Anonymous
SOURCE: i have a hp c6280
I had this same problem with my c6280.
I got fed up (HP only added frustration) and decided to trash it and buy something new.
So I figured I would take it apart and see if it was something obvious, worst thing that could happen was that the printer would not work - allready there.
Here is what I found.
Taking the covers off of this printer is not easy, but after removing all accessable screws I was able to get the covers off.
I found the pump motor on the left side of the printer (it is labled).
The pump motor has a large (approx 2 in) gear on it that is drivin by a belt with teeth.
The other end of the belt is drivin by a small (approx 3/8 in) gear.
There are two belt tensioners on each side of the belt.
PROBLEM; The belt was not riding on one of the tensioners.
This causes the belt to intermitenly engage the gears (stalled pump motor).
I put the belt back on the tensioner, put the covers back on (a real pain).
Printer now works fine.
I think that this may have been a problem out of the box because the lound clicking noise that came with the printer has also gone away.
Posted on May 06, 2009
Anonymous
  • 160 Answers
SOURCE: HP Officejet 6210 will print but with terrible clicking noise
Ok this Sounds Crazy but it worked for me and its easy to try. Unplug the unit and pick it up and turn it side ways and gently shake it. Sometimes a small piece of plastic has broken loose and is interfering with the works and if you can dislodge it from its current location it will stop. Be careful not to hurt youself doing it. Also, I have one printer with a missing tooth on one of the gears and has been growling at me for a long time.
Best of Luck,
RSMITH972278
Posted on Oct 12, 2009
gday777
  • 7 Answers
SOURCE: HP Color Laserjet 2840
You might find that it is the gear driving the fuser, these plastic gears get very worn when driving the ceramic fuser gear. Right Rear plate assembly RG5-7580 with the gears that connect the fuser motor to the fuser.
Posted on May 25, 2010
Rider On Way
ONE-Touch-Solution
  • 1679 Answers
SOURCE: Just Purchased A Hp Office
You mentioned this is brand new printer purchased and gives "Pump motor Stalled" Error. Since this is new unit, my suggestion would be to contact HP Tech support regarding this issue as your printer is In-warranty and if needed, the printer will be replaced without any cost.
OR,
If you have purchased the printer from a store like bestbuy, Costso, Walmart etc. you can return the printer to them and get another one exchanged ( Check their return policy )
HP Contact # - 1800-474-6836
Before you contact HP or return the printer to store, you can try few things to check if it works as "Pump Motor Stalled" generally is Hardware Issue.
Open the Printer front access door.
Remove the Cartridges and Printheads ( Printhead is that holds the cartridges, loosen the latch to remove it )
Clean the contacts ( Electrical or Golden contacts ) using lint free cloth. ( Cloth damped with few drops of water, squeezed properly )
Put the Printhead and Cartridges back and Turn off the printer and turn on.
If should not display the error. If it does, it is your choice whether to take the printer to store and get exchanged or contact HP.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Posted on Jan 03, 2011
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
Just Purchased A Hp Office Jet Pro 8500A. The printer says Pump Motor Stalled. What to do ?
OR,
Regards,
Ron
Jan 03, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP OFFICEJET PRO 8500A NEW OUT OF THE BOX BRINGS US PUMP MOTOR STALL WHEN READY TO PRINT -
Return the machine as it's DOA (Dead on Arrival)/ out of box Failure. Best thing you can do or else you will end up with a lemon, and a loss of money.
Oct 15, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Pump motor stalled
If within warranty then call 1 800 474 6836 (toll free) and get it replaced through HP.
If it is OOW then you will get an upgrade.
Jul 17, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error Message: Pump Motor Stalled. Please advise
Try partial reset and semi full reset of the printer, this is error message is a hardware error, if the issue is still not resolved contact HP, they would replace the printer if it is under warranty.
Sep 28, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Pump motor stalled
Apr 24, 2009 | HP Photosmart D7360 All-In-One InkJet...
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
I have a hp c6280 all-in-one photosmart printer. i changed the hp vivera colored ink cartridges. the printer will not work and prints out that the error is pump motor stalled.....printer documentation...
Jul 14, 2008 | HP Office Equipment & Supplies
HP Photosmart C7280 All-in-One Printer Logo
108 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
