Question about Babi Italia Eastside Classic Crib, Classic Cherry
<!-- from fixya rte -->LOWER THE MATRESS IN THE CRIB - Babi Italia Eastside Classic Crib, Classic Cherry
RSole
    Master:
  • 697 Answers
Yessir! Lower the mattress! Raise the shields!
Posted on Oct 14, 2014
How can i lower the mattress on me sorelle vicki crib? when i bought it it was already assembled and the matress was on the highest level now my baby can sit up so i want to lower it so she will not be...
Here is what I think is your owners manual. Try it and respond if it doesnt help. Good luck, looks easy.
Looks like 4 bolts that have wingnuts are removed and the mattress support brackets can be swiveled lower and the holes on the mattress support further in are used with the bolt/wingnut combo. This lowers
the mattress support.
http://www.sorellefurniture.com/newinstructions/VICKI%20BRU%20CRIB.pdf
Mar 08, 2011 | Sorelle Vicki
Just notice that the matress doesn't set in well... does the crib matress have different sizes maybe??????????????????
Older mattresses are smaller. Make sure you are using the mattress that is listed
on the crib instruction sheet. There is a new standard and all mattresses are made to comply.
Feb 08, 2011 | Graco Lauren Crib
I need the plastic side pieces the crib matress frame sits on
you need a mattress frame on you crib. yes you can have it just go to
this site: http://www.bestmattressreviews.com/simmons-mattresses.html
there it may help with your problem.
regards,
Feb 05, 2010 | Simmons Mattress Matino - Natural Maple...
Need hardware ffor vintage crib
productsamerica.com/page89html has replacement parts!
Jun 22, 2009 | Vintage Lullaby Nest Crib
I dont know howto put the crib together
You can download your manual on Evenflo's website:  Product Support, Replacement Parts.
Mar 09, 2009 | Evenflo Jenny Lind Crib
Simplicity ellis crib to a bed
If you are changing it to a regular twin-sized bed with the headboard, you need a boxspring WITH a matress. Matresses will break down laying directly on a bed frame. A boxspring gives the frame something hard to help support the matress
May 13, 2008 | Simplicity for Children 4-in-1 Convertible...
Matress height
You might want to check out this site. I bet they will have what you are looking for.
http://www.productsamerica.com/index.html
May 04, 2008 | Simmons Mattress Matino - Natural Maple...
Problem install matress support
This is intended for the Simplicity Ellis 4-in-1 crib not the Aspen. My hubby just put together the toddler bed, and he had a problem with securing the screws of the metal mattress support to the crib. He put the screws one by one and there was a gap of nearly 1/2 inch from the crib. He resolved this problem by putting the screws on all four ends of the mattress support, then he tightened the back rail screws (the higher end) first and when he tightened the front rail screws the gap automatically disappeared. I hope I am clear enough on this as I'm not the one who installed this crib, but as he was quite frustrated I thought this might be able to help others who may have the same problem.
Feb 20, 2008 | Simplicity for Children Ellis 4 in 1 Sleep...
Childesigns carrollton crib
I am not familiar with this crib, but I have been through many cribs and they all (so far) are adjustable to lower the mattress. You can figure it out by removing the mattress and matress board and inspecting the way the board is connected to the frame. Often there is a bar or rung that sits in a clip or groove at each corner of the crib just below the matress board. You may have to crawl underneath and look up at it. Usually you will be able to lower the platform without using tools, but be sure to take the weight off the platform by removing the mattress and board. Good luck.
Nov 14, 2006 | Childesigns Carrollton Crib
Babi Italia Eastside Classic Crib, Classic Cherry Logo
Top Babi Italia Baby Gear Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Babi Italia Baby Gear Expert? Answer questions, earn points and help others
