Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
In regards to the capacitors on the board...mine are somewhat raised and there is a white rubberry substance around them. The bad capacitors might be causing the dim display? When I turn it on the screen is so dark that all I can see is a faint object because it is so dark. Are the bad caps causing this?
I would say either the video cable has disconneted, causeing the led that lights the screen up to not function,, simpley take the bezel around the screen, take the small screws aroud the screen to slightley pull the screen away from the back top to see if the cable is, or has pulled loose...If now the screen is bad..
Posted on Oct 17, 2014
SOURCE: Samsung Monitor Backlight/Power Issue
hi, these mosfets are obsolete now, do you know a good equivalent for them?
Thanks
Posted on Dec 08, 2012
