Question about Whirlpool Dishwashers
Whirlpool Quiet Partner II fills with water then starts to wash but never drains it stays in wash cycle the whole time, then it makes a strange chattering sound then starts washing again, after doing
Model DU1300XTVTO Whirlpool Quiet Partner II
jffrchrds
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
Sounds like broken glass in the drain pump.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Posted on Oct 16, 2014
3 Related Answers
xiamjoshx
SOURCE: Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Posted on Nov 23, 2008
Anonymous
SOURCE: Dishwasher fills with water but agitator does not
Already called for service. Thanks!
Posted on Jan 02, 2010
Anonymous
  • 36 Answers
SOURCE: I have the Whirlpool Quiet Partner 1 the wash
If the clean light blinks 7 times thats you heating circuit. Test the heater with an ohm meeting to see if it has open. If so order the heater kit and it comes with the control board.
Posted on Jun 15, 2010
Our Whirlpool quiet partner ii is not filling with water for the wash cycle
It could be a bad fill valve or just the screen for the fill vavle.
Feb 09, 2015 | Whirlpool Dishwashers
Whirlpool quiet partner II starts and stops. What should I check?
the first thing to do is unplug it for 3 minutes then check to see if it reset by running
Jan 07, 2018 | Whirlpool 24 in. DU951PWB Free-standing...
Does my whirlpol du1145xtpb1 dishwasherr need to be reset
SERVICE DIAGNOSTICS CYCLE
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Read more: http://forum.appliancepartspros.com/dishwasher-repair/261055-whirlpool-quiet-partner-ii-clean-light-flashing-have-reset-still-flashing.html#ixzz2UOcsE2Yg
May 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
Why did my quiet partner II whirlpool dishwash just stop mid cycle?
see this possible causes:
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
Timer
sincerely. God bless you
May 04, 2012 | Whirlpool Dishwashers
I have a whirlpool quiet partner ii keeps stopping
DON'T REPLACE THE WHOLE BOARD!!! Are you kidding me? These other answers are a joke. I know exactly what is wrong because I had the same exact problem. I had the same problem with the same dishwasher. Get to the control board panel behind the keypad (from the inside of the door). Look at all the capacitors. If any of them have a top that is convex (bubbling out), then they need to be changed. I had two capacitors that were bad (right next to each other). i ordered the same ones on amazon.com for $5. actually i got a 10 pack. unsoldered old ones. soldered new ones in. works perfectly. these models have a poor electronic board design or a poor overall design that blows these capacitors. Such an easy fix. I read so many internet threads where so many people with the same exact problem and replaced the whole board for $120 minimum if they did it themselves. silly. CHECK ALL THE CAPACITORS FIRST. 95% OF THE TIME when electronics go bad, its a bad capacitor, usually one that deals with the overall power. ~cheers
Jan 24, 2012 | Whirlpool Dishwashers
I have a whirlpool Quiet partner II. It will not fill w/water.
ck the float in bottom of tank . it may be stuck n the up pos .. moce it up and down and listen for click of the sw .. very common . also the water valve may have failed and it will need replaceing . mm
Dec 07, 2009 | Washing Machines
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
760 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
