Please go to the following page to attempt to reset your password:
http://edit.yahoo.com/forgotroot
(If your security questions may have been recently changed, please pick "My account may have been compromised", you may see a 'This is not my question' link underneath each question.)
If you are successful with that process, you can go ahead and skip the rest of the steps...
OPTION TWO:
(Important - if you have another account with Yahoo, please sign out of that account before trying to complete the form below.)
Otherwise, if it is not successful, please follow the instructions below as a 'last resort' account recovery:
Please go to this page:
http://help.yahoo.com/l/us/yahoo/edit/general-01.html
That recovery form was created so that people who cannot access their alternate email or answer their security question(s).
You'll need to have an alternate email account set up so that they may contact you. You can get a free account from www.Gmail.com for this.
Place your alternate email address under the "What is the email address where we can contact you?" section.
It will take 2-7 business days for someone from Yahoo to get back to you.
Thank you.
SOURCE: there is no chat on yahoo messenger 9
in that messanger yahoo chat is available theri u clik join the room after then click enter chat and verifcation wil display selct and clik you chat will started
SOURCE: friends' yahoo messenger ID blocked.Can't add it to my msgr list!
I have used Zak's nobuddy before - it has been updated to work with yahoo's newest protocols.
Test: (A) I have 2 yahoo ID's - I added each to the other:
(B) I use Yahoo Messenger version 9.0.0.2162
(C) I was invisible mode at all times on each ID
1 I then got this zak nobuddy to remove one from the other:
2 It worked (although it left no message - I was simply gone).
3 I then performed the normal add request - this too worked fine and I was added again as soon as ID2 accepted.
You say it's blocked from your contact list:
I would check from messengers menu bar
messenger/ preferences/ ignore list and see if your friends ID is in there.
SOURCE: i am unable to login into yahoo chat
hii friend,may be your age you entered in the sign up page is less thsn 18 years.so you are unable to enter the chat rooms. you get another new id by giving your age more than 18 years.your problem will be solved
SOURCE: i cannot access video call to anybody using Yahoo Messenger 10.
you and your partner need yahoo messenger which have video call facility ask your friend to install same yahoo as you using
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
SOURCE: login to yahoo messenger
you have to download Yahoo Messenger from here.
Install and follow instructions to sign up.
Cheers,
Mike
Leave rate if I helped you, thanks!
