Question about Durabrand DWT1304 13" TV
If your television is fitted with a UHF tuner it should just be that you need to re-tune your set. This is often the case between seasons. If it is not fitted with one, then you need to buy and install a digital set top box to receive all stations, (Analogue, UHF and digital) in your area.
Posted on Oct 14, 2014
Apr 12, 2017 | Motorola Radio Communications
Aug 04, 2011 | Sanyo DP46848 LCD TV
Dec 19, 2010 | RCA R56WH76 Projection Television
Channel 19 actually broadcasts on VHF channel 11 (approximately 201MHZ) and channel 25 actually broadcasts on UHF channel 15 (approximately 479MHZ). I know that sounds a bit weird but it has been done so that stations don't have to change there "call" channel number when we switched to Digital TV. Your digital converter box keeps track of this. This is important to understand because you need and antenna that is good at picking up both UHF and VHF signals. If you're not getting channel 19 it may be due to a poor VHF portion of your antenna. If your using a basic old set of rabbit ears for your antenna that has a loop in the middle then I might have a trick for you. Most rabbit ears have 2 telescopic antenna elements. Extend or collapse until each length is 14.7 inches long. (Which is a quarter wavelength at 201MHZ). You are effectively tuning (Optimizing) your antenna specifically for that channel 19. You may need to rotate your antenna a bit to find the best signal.
There are other factors which can hinder you receiving channel 19 but this is a good starting point. Let me know what type of antenna you have. Hope this helps.
Dec 03, 2010 | Insignia Digital-to-Analog Converter for...
Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
Jan 03, 2010 | Toshiba 19A25 19" TV
Feb 27, 2009 | Samsung LT-P1545 15 in. EDTV-Ready LCD...
Feb 20, 2009 | Televison & Video
Jan 27, 2009 | Curtis RT700 7 in. Portable Television
Mar 21, 2008 | Orion STV2763 27" TV
69 people viewed this question
