When i plug in my iron its red button turns on which indicate that it is getting electric supply but iron doesn't heat up.
SOURCE: iron D2000C type 1 black decker
the folowing reason for not working 1. the connection may be lose 2. the heating coil is gone 3. inside connection may be lose.
SOURCE: Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
SOURCE: the black and decker iron wont heat up
It probably has a high temp overload opened up inside or the thermostat control has gone bad.You can only tell for sure by taking the unit apart and testing the circuit for continuity.The steam feature on the iron is heated by the same element that heats the iron so it wont work.the element itself could also be bad,but I have never seen one go bad.You will have to check each component seperately to find the damaged part.or you can test the whole circuit at the plugs end,and use a jumper across each part until you have continuity through the unit.Make sure the thermostat is turned all the way up.the part that you are bypassing when you get continuity is the bad part.
You can buy a cheap continuity checker at any lowes,or even wallmart for that matter.
SOURCE: Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
SOURCE: I bought Black & decker iron ICR500 8m ago.
Take it back to were you bought and get another one.
