Question about Gateway Computers & Internet
I cannot get front composite video jacks to work. I want to capture video from VCR using Pinnacle.
Posted by larryfish on
  • larryfish Jul 05, 2009
    I am trying to use Pinnacle Studio and the input on my PC (picture link is below) to capture video from a VHS source. Apparently, I was supposed to have ATI Capture software installed to do this. I do not have it, gateway is giving me a broken link, and the ATI site is no help. When I try to use Pinnacle it says "no video signal detected - check cables" ( i did)
    Picture link is below.
    http://www.newegg.com/Product/ShowImage....
  • Anonymous May 11, 2010
    There are a lot of settings and connections required to do something like this sucessfully. Please elaborate as much as possible.
Anonymous
  • 22 Answers
You don't need ATI capture anything. Pinnacle Studio does that. Make sure your composite input is not disabled on your PC. Make sure Pinnacle is setup to capture from that card/device. Make sure your video device is outputting to the composite.
Posted on Jul 07, 2009
I have a pinnacle moviebox 510-usb. The specification contains, you can streaming from analog secam source, but in importer section i can't see any video after switched secam mode, while the vcr play...
Be sure that your MovieBox capture device is selected under Studio's "Setup/Capture Source" selection (assuming you're capturing analog). If the MovieBox doesn't show up in that selection window, there could be a problem with the device.
Additionally, check in the Diskometer left-hand panel (this is found at the center of the bottom of the screen) and see that the correct input port value (either composite or s-video) is selected.
If you're capturing digital, then you'll have to use a Firewire connection to the MovieBox device.
Hope that's helpful.
Dec 31, 2010 | Pinnacle Studio MovieBox Plus - Video...
Capture working from camera but not from VCR
are you getting doistorted picture while using VCR?
Jan 21, 2008 | Pinnacle Studio MovieBox DV 9 (210100349)...
VHS Recording
If it came with the Pinnacle software (Pinnacle Studio), that's what you have to use to move your movies from VHS to your PC.
Nov 19, 2007 | Pinnacle Dazzle DVC 90 (210100371) Video...
No video is shown in the video source display
Hi and welcome to Fixyah,
If you used Instant DVD recorder and there is no video display. Open your IDVDR program
Choose go directly to the advance mode.
select capture source and choose your dazzle device
click on options and click on video input.
>if you used S-Video cable then click on S-Video
>if Composite go ahead and click on Composite.
>click also VCR input.
Now open your camcorder and hit play button. Check if still the same problem.
Jan 31, 2010 | Pinnacle Dazzle DVD Recorder
I can't get composite video capture to work.
No, just check if there wire are plugged into your computer mother board properly and according to the manual...
Jul 05, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
I need a picture of how to hook up the dazzle to the vcr
If your trying to capture from a vcr make sure that the cables "composite are connected at the back make sure it is plug in to the video out.
Next, connect the cables directly to the dazzle.
make sure that the vcr is on and it is playing.
In the program Instant DVD Recorder please go to the step 1 select the dazzle as your video source not pinnacle file capture.
Then click option check the VHS input.
Video input must be composite if your using the composite
Audio input must be the dazzle.
Jul 04, 2009 | Pinnacle Dazzle DVD Recorder
No audio when importing vhs tapes into moviemaker via composite
you need to connect rca jacks or the mini jacks to the anolog side of your sound card and the 9 pin connector will use for video to capture aslo if your using windows movie maker you need to select the imput type and mpeg 2 or mpeg3.
Jun 19, 2009 | Pinnacle Dazzle DVD Recorder
Computer not recognising VCR- what plug should i use?
You need a TV tuner card to be able to read both audio-video signal, else how are you going to covert analog to digital. The VCR gives out analog output.
........sodeep
May 08, 2009 | Pinnacle Studio MovieBox DV 9 (210100349)...
Diamond One-touch video capture audio doesn't work with s-video
i had the same problem.  it turns out the s-video does not carry audio so you have to hook up a separate audio line.  On my camera there is a mini plug a/v jack...so i run a mini plug out to a rca jack splitter and then run rca cords to the red and white jacks on the one touch....then it works great.
Jan 04, 2009 | Computers & Internet
I HAVE dAZZLE FOR pINNACLE STUDIO 9,(WHICH HAS WORKED) BUT ONLY USE NOW AND AGAIN. iT IS CONNECTED TO A vcr AND SOUND COMES THROUGH BUT NOT THE PICTURE - CAN YOU ADVISE PLEASE
in the Selected capture menu, toggle back and forth between Pinnacle file capture and dazzle to see if you can trick it into working for you. Also on vcr, toggle between tv and vcr to see that will help.
Apr 28, 2008 | Pinnacle Dazzle Video Creator Platinum...
Computers & Internet Logo
176 people viewed this question
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
