Car Audio & Video Logo
A
Anonymous Posted on Oct 12, 2014
<!-- from fixya rte -->Installing a model# SE301-VL. - Pyramid Car Audio & Video
DROPNDEAL
Level 3:
Top Expert:
  • Pyramid Master 2,931 Answers
  • Posted on Feb 10, 2018
DROPNDEAL
Pyramid Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932485
Points
21770
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
1 Related Answer
Anonymous
  • Posted on Sep 12, 2008
SOURCE: Pyramid SE301-VL amp wiring confusion...
Captain_Bill,
Red - should be fused & is the +12Vdc system supply voltage.
Chassis = System ground.
Individual Green, Grey, & cooresponding blacks will be the right & left chan Audio ins (Black = neg).
Paired bl/blwh, br/brwh, grey/grwh, & green/grwh will be the audio outs.
Hope this helps !!!!
Dale EE
Where can I find the PC Connect cable for a Sharp Camcorder Model VL-SD2OU
You may be able to find the PC Connect cable for your Sharp Camcorder Model VL-SD2OU at an electronics store or online retailer that specializes in video and camera equipment. You can also try contacting Sharp directly to see if they have the cable in stock or if they can suggest a retailer that carries it. Alternatively, you may be able to use a generic USB cable to connect your camcorder to your computer, depending on the capabilities of your camcorder and computer.
Keep in mind that you may need to install any necessary software or drivers on your computer before you will be able to access the video files on your camcorder
What is considerd,a chassis ground ?
chissis ground is just simply the car body metal, not metal that moves like car seat. drill a hole smaller than your screw and the drive the screw into it with a lug connected to your wiring
1helpful
1helpful
Camcorder is not recognised by my computer.
If you have the disc that came with the camera install it on the computer. It should then be recognized. If not then click here and it will take you to the website to download the drivers.
Click on where it says software and drivers, then enter just the model of your camera (VL-Z5E). After that it should be all gravy.
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
