Samsung HLP4663W 46" Rear Projection HDTV Logo
Question about Samsung HLP4663W 46" Rear Projection HDTV
Picture freezes intermittantly
The tv freezes intermittently and repeatedly
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1helpful
3answers
Picture intermittently freezes.
There is an fault for sure. When you are not a tech, you don't have to know what is wrong. So when the solution from The Knight does not help, contact a tech or visit a repair shop. Ask what they will charge in advance to see if it is worth repairing the TV.
Why does my pvr keep freezing
Sorry can't help on this. Presumably you've switched off/on at mains and checked all connections secure. Would a factory reset help, see tips how to do on fixya, although not sure if you would lose library data.
Picture freezes but sound is ok.what does that mean?
If it lock intermittantly, then check the signal from your aerial.
2helpful
I have the Sony KV-36XBR400. The picture freezes intermittently. Sound is OK. When I turn TV off and on again, I may get a good picture for about 15mins, sometimes longer. Sometimes half of the screen will...
Hi.. Sorry to hear that the Picture is freezing.. Here are some of the steps that you can try:
*Try to connect a different video source with the TV like DVD Player, Blu-ray player and check.
*If the issue persists, disconnect the power cord and reconnect to a different wall outlet without the Power surge protector.
* If the issue persists, you need to contact the nearest service center to fix this.
Yes, you were correct many LCD TVs have problems compared to this TV.
I have a microsoft life cam vx 5000. During video call the video is extremely grainy or "boxy"....audio is choppy....constant flickering in the picture. Cannot go a few seconds without the picture...
Sounds like a network problem. Is your internet connection intermittent? Or maybe a bandwidth problem.
Try using a cabled connection in case you are using wireless.
Close all other applications that are using the internet connection.
Tv-- signal strength normal but signal on all channels "blipping" down intermittently causing freezing of picture. Have replaced aerial with high gain antennae together with aerial cable and...
When ever the picture freezes intermittendly the problem is usually poor connection on the signal line (antenna or connection on tv) or poor reception. Could be the tuner if the tv has one.To eliminate the tuner possibility try anther tv set if possible.
If you still cannot figure out the problem,let me know what kind of set up you have connected to your tv set.
Do you have a satellite or cable box and if you have splitters.
TV shuts off on it's on after about 20 - 30 minutes of play
freeze like the picture is in pause?
picture freezing is desired function on the remote and handled mainly by the "picture and picture" circuits. but the video that is involved and processed there is handled by many circuits and microprocessors.
what you describe is an intermittent heat related problem if you almost can set a watch to the the shut-off time. you can feel, if your a tech, what part is running hot with a finger or start freezing a suspect part with freeze spray and see if stays on long past overdue. make sure your vent holes in the back are not covered and keep the back at least 1/2 foot from the wall.
2helpful
Lg 44" dlp tv
Punch yourself in the face REALLY hard and then throw the TV out the window and buy a 60" Plasma or a 52" LCD
Open Questions:
See all Samsung HLP4663W 46" Rear Projection HDTV Questions
 Grubhead
Grubhead
