Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
A
Anonymous Posted on Oct 12, 2014
How do I adjust the temp. in the refrigerator:model gSF26C4EXTo2
Adjusting temp on 2week old refrigerator from 10 degrees freezer/44degrees refrigerator-to-0 /37.My temp contro is digital with adjustmrnt button on Left & 4 lights right-set to reccomended settings.
didnt specxify make or model --generic answer--your owners manual can explain how to operate the unit ---or search online for a manual using make and model
Will not let me adjust the temp. beeps and resets when temp is adjusted
It would of been helpful to have the model number so I am guessing what yo have, with that being said. One you have adjusted the temp it beeps to tell you the temp is set and then the display returns to what the temp is actually inside the refrigerator you will have to allow 24HRS of operation to achieve the new temp you set.
2answers
Food is freezing in the fridge.
Obviously you should replace thermostat.
No... I don't know how to do it. Happened to me the same and called a technician to do it
What should the freezer and refrigerator temp be set at its a side by side model #HSS25GFTAWW
optimum temp is freezer -18C and fridge+5C i personnally reccommend a stand alone thermometer,that way you can adjust for summer and winter.
My model is ARB 1914 CC nine years old.
your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
I have an arcticaire a40ra model which usually holds temp at 4C. I came into work this morning and everything is frozen. I don't see a thermostat to adjust or reset temp. How do i adjust the temp?
There has to be a control somewhere on the fridge. Some newer models have digital controls located on the outer doors panels, or its going to be inside. Read your owners manual
www.FixMyFridge.net
Frigidaire refrigerator model #FRS26R4AW7 is freezing up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
1helpful
Refrigerator cools, but not cool enough, even with temp adjustment turned to coldest setting. Freezer only gets down to 0. Fridge at 44 degrees
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
My refrigerator is freezing everyting
ur temprature knob is not adjusted so u have to read the manual ok.read it and adjust it
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
