Question about Vtech Mobigo Learning System
How do i re-calibrate my sons mobigo
When we turn on the game the games are not working properly cause screen is not calibrated correctly
5 Related Answers
Anonymous
SOURCE: my sons mobigo touch and
Looks like it is a bit of a ploy to get the child's progress. You have to download the Learning Lodge Navigator and connect your son's device to the computer. It will download his progress. When you are done it will show some trophy icons on the login screen. That's the "reward."
Posted on Jan 01, 2011
WA Mom of 3
SOURCE: My son's mobigo screen looks cracked on the
Does the crack look like it has black ink or lines around it as well? If so, this happened to my son's Mobigo and, unfortunately, the system is now toast. I called the store where we bought it and they told me to call V-Tech because it should still be under warranty. However, V-Tech informed me that it is not under warranty for damage and that they cannot repair their toys at all. There is nothing that can be done with it. They did offer of discount for a new V-tech purchase though.
Posted on Apr 08, 2011
Mary Ratliff
SOURCE: My mobigo and the original
Hi Julie, my granddaughter's mobigo is doing the same thing...have you figured out the problem? I don't know what to do either.Mary
Posted on Nov 19, 2011
sophie s
SOURCE: my son's vtech storio's touch
my sons v tech storio wont turn on and im using rechargble battries can some please help
Posted on Dec 31, 2011
stefaniequic
stefaniequic
SOURCE: my mobigo stay on the screen that says choose a game
Try taking out the batteries and the game and holding down the "on" button for one minute, then put the batteries back in and try again. The tech support will tell you do that anyway. If that does not work, I would contact them for repair or replacement. I had that problem and that is what I was told to do, they ended up replacing my daughter's mobigo at no charge.
Posted on Jul 20, 2012
When i turn my 3ds on you can see all the top screen but not the bottom screen
Plug it into the charger first.try calibrating the touch screen.
you can get to the calibration menu without touching the touch screen. First, turn off your system. Hold down L+R+X. While holding these buttons down, press the power button. This should take you to the touch screen calibration menu. (See Nintendo 3DS Operation Manual, Page 15)
If it doesn't work,you need to replace the bottom screen.
please note that all games dont require the bottom screen
Jul 01, 2012 | Video Game Consoles & Games
Tip
How to Sync Stylus with LeapFrog Leapster 2 Learning System
If you need to sync the device to the stylus just follow the steps below.<br /><br />1. Turn your <span>Leapster</span> 2 off, and remove the game cartridge<br /><br />2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.<br /><br />3. With your finger still firmly on the 'hint' button, turn the <span>Leapster</span> 2 back on. Keep your finger on the 'hint' button.<br /><br />4. The screen should be displaying the calibration screen. You can release the 'hint' button now.<br />5. Press the 'A' button on the right to enter the calibration screen.<br /><br />6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your <span>Leapster</span> 2 throws at you.<br /><br />7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.<br /><br />8. Your stylus and touch screen should now be working, enabling you to sign in as usual.<br /><br />9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.<br /><br /><b>Thanks for <span>using</span> <span>Fixya</span></b>
on Mar 09, 2011 | Toys
I can't calibrate the leapster.I can't get pass enter a name
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
1. Turn your Leapster 2 off, and remove the game cartridge
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
If you have questions please let me know.Thanks for using Fixya
Aug 03, 2011 | LeapFrog Leapster 2 Learning System
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
The touch screen does not respond to the stylus what can i do?
Thanks for using Fixya,
Mar 02, 2011 | LeapFrog Leapster 2 Learning System
Logitech Wingman Extreme Digital Calibration
Hello there
Usually these JS automatically calibrate when intalled, but...some like olders models, have problems, with sensors, or bad calibrations inside the rotor ans sensors area. for those fixes, you have to open carefully the JS and look for the sensors that usually are two optical sensors, and clean good, with computer air spray, sometimes that did the trick, but others, its a sensors, problem. you have to RMS the product, or use your warranty.
hope these helps!
Mar 02, 2017 | Logitech WingMan Extreme Digital 3D...
Nintendo DS touch screen not working properly
Turn the ds on without a game in it and go to the settings icon (looks like a tiny ds) on the bottom middle of the screen then go to the far right yellow icon and it will re-calibrate the touch screen and let you know if calibration was a success.
Jan 11, 2009 | Nintendo DS Console
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Stylus Does Not Match Up With Touch Screen. Has Been Like This For Ages. Sent It Back Once But Did'nt Make A Difference. Could You Maybe Give Us Some Money Back?.
I think your touchscreen must not be calibrated correctly. Turn on your ds without a game and go to the little tiny ds a the bottom. Then click on the yellow orangish icon and it will start calibration. Just touch the marks with the target things to calibrate it.
Jun 23, 2008 | Nintendo DS Console
Calibration of screen
You will find information how to calibrate your screen here directly from Nintendo. Hope it helps.
http://www.nintendo.com/consumer/systems/ds/recalibrate.jsp
Mar 02, 2008 | Nintendo DS Console
Vtech Mobigo Learning System Logo
107 people viewed this question
Top Vtech Toys Experts
ThaMp3Doctor
ThaMp3Doctor
Geoff
Anthony Ward
Anthony Ward
Are you a Vtech Toy Expert? Answer questions, earn points and help others
