Question about Pride Celebrity X 4-Wheel Electric Scooter
Can I bypass the speed pot - Pride Celebrity X 4-Wheel Electric Scooter
can I bypass the speed pot
Gino Borg
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
No, the controller checks the resistance of the combination of the speed and throttle pots on startup.
Posted on Nov 06, 2014
Mrs Caroline Dickson
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
My scooter is giving 5 beeps when i turn it on what do i do to rectify this problem ?
Posted on May 09, 2016
I replaced the speed pot and throttle pot now my rascal 235 drives but only about half speed
Sounds like one of them has incorrect values. You need to check the resistance marked on the original speed and throttle pots, with the new ones. Generally a throttle pot is 5Kohms and 20 or 200 ohms for the speed pot.
Oct 15, 2014 | Health & Beauty
Rascal scooter
Could be the Throttle Pot or Speed Pot. The levers will change the resistance of the throttle pot. The speed pot feeds the throttle pot.
Move the speed pot while pushing the lever forward. If it works could be the speed pot has a dead spot on it. Also check wires loose and a mechanical issue with the throttle pot and the springs.
Apr 04, 2014 | Health & Beauty
That is the speed pot
Hi , the throttle pot , not the speed pot, that is the lever is fixed to, you push to go forward or backwards, please can you tell me the make and model of this scooter ?
Regards
Rob
www.gewizrepairs.co.uk
Feb 28, 2014 | Pride Health & Beauty
Mobility scooter
The usual remedy is to replace both the tiller pot and speed pot at the same time. If your battery gauge is NOT dropping when speed is dropping then you need a tiller pot replacement as well. These parts have a typical 3-5 year life expectancy.
Oct 25, 2013 | Health & Beauty
Wiring
Not sure about the actual voltage, but the primary power board shows 94 V @ 2A. As this appears to be a variable speed drive, the voltage amplitude should vary depending on the speed potentiometer setting. The most likely culprit is the speed potentiometer. Poor design causes vibrations on the printed circuit board. This induces metal fatigue in the potentiometer terminations at the board. Eventually one or more terminals snap off. You could try removing the pot and connecting the wiper termination connection directly to the relative end for full speed? This is assuming you want it to run at full speed? Failing that you could try variable resistance settings and then replace the pot with a fixed resistance for the required final speed?
Sep 14, 2012 | Dremel Multi Max Kit
What makes a speed pot go bad on a celebrity x 3 wheel scooter?
Yup you got a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pot is a variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should move gracefully up to 30k down to zero as the pot dial scooter speed increases. Failure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Jul 23, 2012 | Pride Health & Beauty
Scooter has very little power just replaced both batteries what else do i check
check the spped control pot and the throttle pot. You will need a ohm meter to check both pots Usually replacing the speed pot will help but it could be both speed and throttle pot Hope this helps
Jun 09, 2011 | Drive Medical Daytona 4-Wheel Power...
Jaguar xj6 4.0 1990. showing fault code fuel 14, fail 14. what does this code mean ?
2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Nov 09, 2009 | 1990 Jaguar XJ6
Bypassing renkus heinz p1500 potentiometer. I need to bypass the potentiometer on my amp. I cant get parts and the pots are bad. I just want to bypass them and run the amp full out. can you advise?
As the pots are part of the necessary feedback loop for the final stage, I would recommend that you jumper the wiper of each respective pot to its "full on" position. Problem solved!...accordianman
Feb 24, 2009 | Audio Players & Recorders
Pride Celebrity X 4-Wheel Electric Scooter  Logo
437 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
