Question about Dryers
Speed queen dryer agm4199w heats up and shuts of
Dryer heats up and shuts off soon after. Sometimes it repeats the process while others you must wait five to 10 minutes
Jorge Rendon
  • Dryers Master
  • 5,420 Answers
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Posted on May 04, 2015
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: Dryer shuts off after 10-15 minutes
The motor is overheating and shutting down, cooling down, overheating again. Motors are expensive and tricky to install. PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
Posted on Oct 03, 2007
Anonymous
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Replace the coils READ THIS!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 14, 2009
Anonymous
  • 4 Answers
SOURCE: dryer gets hot and shuts off after five minutes,
Check your vent tube to make sure it is clear. It is probably getting to hot because there is no ventilation to the outside. When you have the front off, check all the way from the lint filter to the outsid of the house.
Posted on Apr 19, 2009
Anonymous
  • 525 Answers
SOURCE: dryer heats up ,then loses heat after 10 minutes
Based on your description, you may have a Gas Valve Coil failure. Below is a link, courtesy of www.repairclinic.com, showing the part(s) involved. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8c237i3479&PartID=3479
More assistance below: You will need your model number to access the information.
Model Number Locator Tip
1. A zero in the model number might be the letter O.
2. A lower case L might be a 1.
3. Some models have 3 digits and a period first, like this 555.66666666
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag.
1. Parts Breakdown/Disassembly Procedures: http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
2. Diagnostic tips: If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Aug 27, 2009
Speed queen electric dryer heats for about 8 minutes then heat goes off and does not come back on
The duct may be clear but the exhaust on the back of the dryer may be blocked. You have to take the back off the dryer and check where the blower is. Good luck.
Mar 25, 2014 | Speed Queen AES28AWF Electric Dryer
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
My speed queen model# AES68AWF doesnt heat what could it be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 16, 2011 | Speed Queen AES68AWF Dryer
My speed queen dryer model #AES68AWF doesnt heat what could it be?
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
My speed queen gas dryer comes on but will no longer heat. The igniter is fine.....passes the Ohm test. What might be the solution? And what are the est. part costs....this is an old speed...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It works on amps... not ohms...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Dryers
Speed Queen Commercial Dryer model EE111OL (electric) got wet in recent flood, still spins but not getting heat. Is it the thermostat, sensor or igniter that is bad and needs replacement?
If this dryer was submerged any component that was in water needs to be replaced. NOT cleaned and reused. there could be water in he burner and any electrical or mechanical component that was in water will soon fail if it hasn't already. This is a safety issue. Please have this repaired as if your life depends on it as it may.
Eric
Jul 30, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer will not heat up Does run
It's probably the thermostats that are normally attatched to the element or it could be the element itself. They are nprmally placed in the rear of the appliance.
The thermostats will only cost a few pounds.
Mar 12, 2010 | Speed Queen Dryers
Speed queen gas dryer uses pay cards
overheating and shutting off,
usually is a blockage in the venting
check the exhaust lines to the wall vent/exits, there may be lint build up in those dryers that are shutting off
Aug 28, 2008 | Speed Queen CGS68AWF Gas Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
