When the Samsung Fax Machine is turned on it makes a kind of clicking noise for about 20 seconds then that noise stops and it says "please wait warming up" It trys warming up for about 30 seconds, sto
A communication failure occurred between the two machines.
The user at the remote machine might have pressed the Stop key.
The call waiting service can cause this error. The click, heard for an
incoming call, is actually a momentary disconnect of the line. Do not
use call waiting on a line with a fax machine.
The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Set the host machine to receive at a slower transmission speed.
Retry
the fax reception at a different time when telephone line conditions
have improved. Call the telephone provider if line conditions fail to
improve. These errors can occur if the phone lines in the area to be
faxed are old or there is noise (static on the phone line). Other
reasons can include power brownouts and other power-related problems
my all incoming fax is going to machine memory, my machine is samsung SCX-4521F, please advise me how can i solve the same & i wanted to take incoming fax in directly computer, kindly tell me setting of the same. Thanks
You can download the detailed User manual by a click on the following link.( http://olsonbros.com/samsung/specs/pdf/ib-sf755p.pdf ). May be it will take a few seconds to download.Please wait.Hope this helps.Please don't forget to rate me if satisfied.Thanks Linda for choosing Fixya.
I have similar problem, but it makes clicking sound also without a toner. And printer is powering off and on continuously. On the display there are some bars, nothing readable. After a minute or so it says Warming..., than it goes off, and so on and forth. Printer is in use on a daily basis.
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems.
Error 232 Definition
Check the following items:
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Try sending and receiving faxes on a different fax line.
Try using a different telephone cord.
Have the phone company test your line for static or noise problems.
Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly
Solutions
If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Hi try changing the fuse in the plug first. Once you have done this then power in and open the cartridge cover and press the cartridge button. If the cartridge moves then the LCD has blown and will need replacing if nothing happens then unfortunately the power supply board has blown then replacing the whole machine is the cheapest option.
