Question about Peavey XR 1220 Powered Mixer Mixer Powered
What amp setting do you use when you have two passive monitors 1 ea on amp 1 and 1 ea on amp 2?
Trying to set up two monitors and use the board to control the volume and settings in each.
Posted by Brittan Buchanan on
Megasong
    Scholar:
    New Friend:
  • 125 Answers
You have two monitor outputs, each controlled by a fader. Plug the amp(s) you will be using to power the monitors into these, connect the monitor speakers to the amp(s) and you're set up and ready
Posted on Feb 22, 2015
How to hook up passive monitors to a powered board
As opposed to front of house? If you want separate amplification of a monitor system then use either the aux send channels or sub-channel outputs or control room outputs (but check these are not amplified already) connected to a separate amplifier to power your passive monitors
Feb 20, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Oct 18, 2017 | Behringer Europower Pmp5000 Powered Mixer...
HOW DO I HOOK UP PASSIVE MONITORS TO BEHRINGER PMP4000
If you are using the amp in stereo mode, then you will require a separate amp for the monitors and the input of that amp are taken using BALANCED TRS cables from the monitor jacks. If you are using the amp as MONO and monitor, then connect NO MORE than two 8 ohm speakers to the Speakon plug on the back labeled for use as monitor. Refer to your user manual... they have detailed photos of the connections. If you lost your manual, you can download another from the Behringer site. There are settings you need to do to configure the unit after connecting your speakers. The small slide switch has to be set to the center position for Main/Mon. Make sure it is centered as many people have had it slightlyu off and the system will NOT pass audio. You need to set each channel "monitor 1" level control to send the monitor signal to the MONITOR mixing bus. You will then use the MONITOR 1 slider to control the amount sent to the monitor. Be VERY careful of grounding the sleeve of 1/4 inch jacks that originate at the Speakon power amp outputs as the SLEEVE of channel A is the HOT side and you can blow the power amp for the channel... it is EXPENSIVE to repair.
Sep 30, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
Hi, How do I connect a powered subwoover to my PMP 6000 when i have connected 1 pairs of passive speakers to Output B and 1 pair of passive monitors to Output A . Ampmode switch set to Monq1 and Mono...
hi,
this mixer has output's from cd/tape(rca plug) that can be used to connect an additional amp for output to a sub. It is designed to use for recording but may also server as a pre-amp output to an external amp of choice.
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 26, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
Aux1 and 2 are not working...what is the fix on the emx5016cf yamaha board
You are NOT trying to drive speakers from the aux outputs are you? These are LINE outputs that should be using TRS balanced lines to either powered speakers or amplifiers. Often these are used for monitors. The monitoors MUST be powered versions or use external amplifier if the speakers are passive..
Apr 26, 2011 | Yamaha Emx 5016cf 16 Ch 2x500w Powerd...
Hey, i bought a new pair of samson auro D415 speakers and i connect them in parallel because one of my main mixer outputs ain't working.but even if al my signal gains and fader levels are low,the peak...
Check only one active speaker at the mixer output and report the results.
Connect only one of the audio inputs from the power amp at the mixer output (and the passive speakers at the output) and report the results.
Sometimes (in parallel connections) there are interferences from the volume controls.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 30, 2011 | Samson Auro D415 - 2-Way Active Speaker...
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Bought a powered monitor as it said to do in the owner's manual, even though I thought it was weird as you usually use a passive monitor with a power amp. Purchased Kustom 10" powered monitor, hooked...
You haven't mentioned what model and manufacturer the mixer is. I will have to guess and say that the monitor out on the board isn't providing signal to the powered monitor or the monitor out on your board is powered and is now damaged by plugging a powered monitor into it. Carefully reread your manual and determine if the monitor out on your mixer is powered or line level. Reread also and make sure that the signal you are monitoring is assigned to monitor out, levelled correctly etc. If you find that the monitor out is passive (line level) try hooking it up to an external power amp and speaker. A guitar amp will do for testing purposes. Start with a low input volume on the amp. Also make sure that if it is passive to use a shielded cable from monitor out to input. If your board has powered monitor outs you can use a speaker cable from monitor out to speaker input (non powered monitor speaker).
Dec 10, 2010 | Kustom Profile 2 PA Speaker / Mixer Stand
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Oct 05, 2010 | Numark CD Mix2
Peavey XR 1220 Powered Mixer Mixer Powered Logo
108 people viewed this question
Top Peavey Music Experts
ray gallant
rhodesworks
Are you a Peavey Music Expert? Answer questions, earn points and help others
