Question about Sunpentown V-520 Health & Beauty Belt w/Foot Massager
I bought the machine in less than a month is not workmakes a hell of a noise
I will use, a high noise live in ap then you can not use
Posted by marlene zonta on
Hi, we have a high definition multi-media karaoke player but if we press enter in karaoke, the select song will not appear... We just bought it in less than a month. Please help us.
Hi Joy.
To help you further, people need to know the make and model, as they differ from one unit to another.
If less than month, surely it still has a guarantee?
Otherwise ask the friendly sales staff at the store where it was bought - it may just be operator error.
Dec 04, 2017 | The Audio Players & Recorders
Which models of access points can WS-C3850-24T-S support?
The following models of access points are supported: LAP1040, LAP1142, LAP1260, CAP3700, CAP3500, CAP3600, CAP2600, and CAP1600, AP700I, AP700W, AP2700 and AP1530 (No mesh). And you can bought the AP products with 40%-80% OFF at 3Anetwork.com. Good luck to you.
Mar 20, 2015 | Computers & Internet
My Asko font loader is 9 years old. just lately it has been making a high pitch squeaking type of noise each time the machine is turning during the washing cycle. It did this in the first six months of...
Hello, as far as your unit makeing a high pitched squeaking noise you would have to remove the top panel of the machine by unscrewing the 2-3 screws along the back upper part of the machine. You would then slide the panel towards the rear of the machine and then remove the panel from the machine. After you did this you would then run the machine and try to distinguish if the noise was being made from the main bearing in the unit which holds the inner and outter tub together. Or if the noise were coming from the motor in the unit. Most of the time when someone does describe a high pitched noise that is described like a jet taking off when the unit goes into the spin cycle this would tend to point towards a main bearing issue with the unit. To replace a main bearing in a washer is a very costly and long proces if done by a technician and most do decide not to fix the unit due to this. On the other hand if it were a motor noise that you were hearing or a pulley noise which on some is located on the back of the tub these are much less costly repairs as well as less time consuming. If you have any other questions message me back. I await your reply
Thank you,
Rick
Nov 27, 2011 | Asko W6661 Front Load Washer
Very light prints but have replaces the cartridge twice. Can't get to get darker...even when you change exposure. Less than 6 months old.
You may have a problem with the high voltage power supply. If your machine is relatively new, it may be the best thing to return it to the place where you bought it for warranty service.
Mar 05, 2011 | Canon imageCLASS D320 Digital Copier
Noise from hell
Turn down the mic volume down on your chat settings.
Jul 16, 2008 | Jabra BT125 Headset
Humming noise
Most times a humming noise in a Plasma tv is associated with high altitude. If you live over 3500 ft. and when you first turn on the unit is has a slight buzz and it gets worse as it warms up then you have what is referred to as high altitude sickness. You shoul contact the manufacture with this problem and the should exchange the unit with one tested for proper operation at high altitude. If you do not live at high altitude then there is a problem in the unit that should be diagnosed.
Dec 18, 2007 | LG 50PX5D 50 in. Plasma HDTV
My Lexmark all-in-one printer which I've had less than 2 months, began making a horrible noise and perforating the right side of paper.
Hi, If you are having this kind of problem so soon after buying the machine I would take it straight back and either get a replacement or a different machine altogether.
Nov 21, 2007 | Lexmark X5470 All-In-One InkJet Printer
Sunpentown V-520 Health & Beauty Belt w/Foot Massager Logo
Top Sunpentown Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
