If the remote is working, but not with your receiver, there is maybe ID mismatch. Both the remote and receiver can be set to either ID1 or ID2 - this is used when you have 2 receivers nearby, so that both of them don't react on commands from both remotes.
See the "Advanced setup" of your manual. On receiver you can check/change the ID code by powering the receiver on (press STANDBY/ON) while holding down the STRAIGHT button on front panel. Display will show "Advanced setup". Use "program < >" keys to navigate the menu until you got to "REMOTE ID-XYZ". Then press STRAIGHT to select ID1 or ID2. Now press STANDBY/ON to turn the receiver off. After turning it on again, it will use the new settings.
You can also try to reset the remote control codes to factory defaults. On remote, press CODE SET with a tip of a pen or pencil. TRANSMIT light on remote will blink twice. Now press SETUP on the remote and then "9981". TRANSMIT should now blink twice and remote control is set to factory default codes.
SOURCE: remote controll
Try these: 0055,0605, 1095....taken from my RX 520 remote codes...might work.
SOURCE: I want my Comcast remote & Yamaha RX-661 to communicate??
30176 or 31176
I am guessing at what remote you are using, so the code may not work. If that is the case, go to the following link and pick your remote from the picture list.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
