How do i program a radio shack 15-2200 5-in-one remote control to recieve a sharp tv code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Codes
hi,
heres what I found
might I suggest taping a piece of tin foil to the back of the remote, or put some velcro on it and stick it up and away. dogs hate to chew on metal, unless theyres food directly on it! (we have three shepherds)just a suggestion, heres the link, youll need adobe reader, hope thats the right remote. if not I found that info at www.radioshack.com and navigated to that remote type and in there I found it.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502147_PM_EN.pdf
J
SOURCE: i need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's
right say it with me....He...Rocks...hehe...but anyway here is the link
address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
SOURCE: Radio Shack 3 in 1 remote code...
i need the codes for a radio shack 3in1 remote #15-2147 also the codes for an orion tv
SOURCE: Program Radio Shack 15 2142 remote for converter box
only if the converter box is using older codes that were in use when the remote was made.
