A 9 flash indicates a brake issue. Make sure the motors/brakes are both locked into gear before turning on the chair. It could mean that one of the motors is unplugged from the main controller or a wire is broken between the motor/brake and the main controller.
Code 9: brake fault. Check motor connections and make sure that the levers are in the engaged position - if you can roll the chair the gearbox is not engaged.
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
