Question about Oster 12-Bottle Wine Cellar - Black
<!-- from fixya rte -->How much are oster 12 bottle wine coolers - Oster 12-Bottle Wine Cellar - Black
5 Related Answers
Anonymous
SOURCE: oster 12 bottle wine cooler
You must remove the fuse from the circuit board to check it. More than likely it's blown. A continuity test while in the circuit will always show the fuse as being good due to feedback through the circuitry.
Posted on Nov 22, 2008
Anonymous
  • 7 Answers
SOURCE: wine cooler temperture
blown fuse in back panel, there are two of them, one you can see, one is in black shrink rap, this is probably problem fuse. It was on my unit and had to cut away the shrink rap and solder in new fuse. Found the problem fuse in top left of panel in back of unit, hope this helps.
Posted on Feb 23, 2009
Anonymous
SOURCE: No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Posted on Apr 19, 2009
Anonymous
  • 82 Answers
SOURCE: oster 12 bottle wine frig, how to set temp instructions please
I suggest you return that puppy as fast as you can.
The company that makes them took bankruptcy and warranties are no good.
To top it off the fans usually **** out in 6 mos or so.
Posted on May 15, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
Posted on May 21, 2009
COOLER IS GETTING POER BUT NOT COOLING. TEMPERATURE CONSTANTLY SHOWING 72 DEGREES.PLEASE SUGGEST TROUBLE SHOOTING. #K0700305460011335 MODEL: OW0912H6H
Check the lint trap behind your cooler to make sure it isn't clogged... I had the same problem and after vaccuming the lint trap, my cooler started cooling again
Feb 06, 2010 | Oster 12-Bottle Wine Cellar - Black
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine frig, how to set temp instructions please
May 15, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine cooler temperture
Jan 19, 2009 | Oster 12-Bottle Wine Cellar - Black
Fast start option does not work
I'm not sure how you ended up under this classification;
All Products > Oster > 12-Bottle Wine Cellar - Black > Troubleshooting
but your problem with an undescribed brand and model will not likely ever get a response.
I think your question is in regards to a microwave oven. Try reposting it with the correct brand and model #.
Nov 06, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster wine cooler fuse
I just replaced mine with a "Slo Blow" and it is working just fine. Got it at Radio Shack , 4 for approximately $3.
Sep 25, 2008 | Oster 12-Bottle Wine Cellar - Black
Broken door...
Buy a dented unit on eBay and take off the hinges
May 12, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12-Bottle Wine Cellar - Black Logo
97 people viewed this question
Top Oster Furniture Experts
Tom Chichester
ray gallant
Are you an Oster Furniture Expert? Answer questions, earn points and help others
