Worked all the time until a new cartridge was placed. Signal via wireless Modem
SOURCE: hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
SOURCE: HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers
i hope this helps you out
richard from chicago
i just noticed you have the wrong cartage
you need hp 57 color
that will make all the difference :-)
HP Officejet 5500 series
All-in-One model
Black cartridge
Color cartridge
HP Officejet 5505
HP 56
HP 57
HP Officejet 5508
HP 56
HP 57
HP Officejet 5515
HP 56
HP 57
HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v
HP 56
HP 57
HP Officejet 5600 series
Replacing the print cartridges
Aligning the print cartridges
The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
SOURCE: REPLACING INK CARTRIDGS
For HP 5510 series for replacing the cartige, you need to lift the door just above the paper tray. Pull out the old cartidge, hold it so you can see the way it is inserted and click in gently in the same way.
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
