Question about Lexmark X7170 All-In-One InkJet Printer
If Lexmark ink Cartridge carrier can be replaced
The cartridge holder broke - the latch completely off. Can this be replaced and if so the cost.
5 Related Answers
Anonymous
SOURCE: Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
Posted on Sep 12, 2008
Anonymous
SOURCE: Refill cartridge for lexmark X6570
please note that I am not an expert, in this field just an attorney and that is why I am putting my full disclaimer right here at the top---That i am not an expert but only speaking from experience.
Earlier this morning, I just pulled the cartridges to check the Lexmark print (X6570) cartridge numbers (41&42). When I typed these numbers in on inksell.com to retrieve the price and other information for these cartridges, they did not have any refill kits or anything of that nature for these specific cartridges.
To answer your question about why the printer is not detecting that your cartridge is full is probably because the cartridge has a chip in it that essentially disables it once the original manufacturer ink is empty. tHEY [Lexmark & Dell] do not want outside competition In other words, the printer manufacturers make the bulk of the money on selling new cartridges (for a fortune) . To make matters worse, they always seem to be half empty even though they are ‘brand-new’ ink cartridges The bottom line is that the faster you can go through a printer cartridge, they can sell many more of the cartridges that they are charging us a fortune for.
Needless to say, I am just going to go and get me another HP printer. My advice would be to check to see if ink-refill kits (see sites like inksell.com) are available for any future printers that u purchase.
Posted on Nov 08, 2008
Anonymous
  • 115 Answers
SOURCE: Lexmark x4850 ink levels won't reset with new cartridge
Hi...
Silly question, but I have done this myself. Have you removed the tape from the bottom of the cartridge?
Posted on Jan 25, 2009
Anonymous
  • 62 Answers
SOURCE: Lexmark X3550 ink cartridge #23 receiving error
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue. The upgrade for the X3430 is available from Lexmark at:
To install the firmware upgrade,
  1. Make sure the printer is ON and connected with a USB cable.
  2. Download and run the appropriate firmware upgrade for your computer.
  3. Be sure not to disconnect or power off the printer until the upgrade is complete
When the update finishes the printer will restart and will accept the cartridges. Please contact Lexmark support if this does not fix the problem.
A similar patch is available for the X3430 and Z1420 models. See http://bit.ly/LoXxv
Posted on Jun 25, 2009
pineworks
Clive
  • 4345 Answers
SOURCE: My Lexmark X5410 Printer will not recognize a refill cartridge.
Hi there
This is the same old story with Lexmark printers, you cant do any thing about it the chips have a small fuse inside them and soon as they emty it blows the fuse, and thats it so I beleave the only way is to buy new ink, or a diferent printer.
Not know any fix for them myself sorry.
Can try.
Turn printer off. Unplug power cord and other cables. Wait 30 seconds. Plug cords and cables back in.
Also seen this on the net.
Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
but yeah, best bet, never ever buy lexmark.....:)
http://www.fixyourownprinter.com/forums/inkjet/35235
If that doesn't work, try disabling your ink monitoring software.
All The Best Pineworks
Posted on Feb 21, 2010
Testimonial: "Thanks for the quick response. I'll try these things...and not buy Lexmark again."
Printer not printing
When this error appears in your printer check if ink are smeared on the holder where the contact panel is with the cartridge. To fix this issue use the Kleenex (perfume ) added with few drops of water to dampen it and clean off those contact on the holder. You should let the unit sit 24 hours for best results. Before printing anything run aligned the cartridges a couple times then run clean cartridges a couple of times. Print the test page to look for the condition.
Thank you !!
Jun 28, 2010 | HP Officejet 5610 All-In-One InkJet...
Cyan toner missing message. on magicolor 330
Firstly - remove and reseat the cartridge. If problem remains: Replace the cartridge with a new one. It is possible the new cart is faulty. If problem remains: Cart Sensor unit should be replaced as follows (If you need a copy of the service manual, contact http://www.TheServiceManualShop.com) Removal 1. Remove the Fuser Assembly (RRP 9.80). 2. Reach inside the empty Fuser cavity and slide the Cartridge Sensor Holder forward to unlatch the Holder from the printer frame (Figure 1). 3. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame and the Holder is free of the frame. 4. Disconnect P/J 87 from the Cartridge Sensor. 5. Remove the screw securing the Cartridge Sensor to the Cartridge Sensor Holder and remove the Sensor (Figure 2). Replacement 1. Position the Cartridge Sensor onto the Sensor Holder so the LEDs face out. 2. Line up the position tab and screw hole on the Sensor with the two holes in the Holder. 3. Use one screw to secure the Cartridge Sensor to the Sensor Holder. 4. Reconnect P/J 87 to the Cartridge Sensor. 5. Position the Holder against the Holder cutout in the printer frame. 6. Move the Sensor wire harness so it exit through the cutout at the rear of the Holder. 7. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame. 8. Push the Holder forward until the front latch secures the Holder to the frame. 9. Reinstall the Fuser Assembly (RRP 9.80). If the problem remains, then the MCU PWB will need replacing. This could put the machine Beyond Economical Repair.
Jun 12, 2007 | Minolta magicolor 330 EX Laser Printer
Need part number for the green door latch it broke
I think this might be a futile effort. Check with Sharp to be certain But generally any machine that uses ink instead of toner is a throw-away unit because it's less expensive to replace than repair. In many cases the parts aren't and never were available.
Sep 21, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Some idiot broke the cartridge latch ...
Brother does not sell spare parts to consumers. You need to call an Authorized Dealer
Aug 10, 2009 | Office Equipment & Supplies
Cartridge problem on HP PhotoSmart C4280
you have to replace cartridge holder assembly.. that will fix your problem..
Apr 21, 2009 | HP PhotoSmart C4280 Laser Printer
Upper door latch needs replacing
entire dooor replacement is best course here. even if the part is availaable seperatly, youll need to order afewdifferent parts that you will break to get into as well as the extra labor to remove and reinstall the parts, the complete door ( if available and cost prohibting) is usually best course of action
Mar 20, 2009 | Panasonic Microwave Ovens
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
How do I install a new cartridge holder?
Click this link for a service manual free download for your multipass c2500 inkjet printer troubleshooting.
This will help you replace the holder.
If you cannot click just copy and paste the following link into your browser window.
http://www.nodevice.com/search.html
Apr 30, 2008 | Canon MultiPASS C2500 InkJet Printer
Color latch part
Part #'s are
ASSY-LATCH BLACK - C6490-60011
ASSY-LATCH COLOR - C6490-60012
Parts re-sellers for HP:
United States Big Blue Products, Inc.
Huntington Station, NY
Tel: 888-BIGBLUE
http://www.bigblueonline.com/hp.htm
Bradshaw Group, Inc.
Richardson, TX
Tel: 972-644-7558
http://www.bradshawgroup.com
Computer Exchange LTD
Lawrenceville, GA
Tel: 770-806-3939
800-883-0800
http://www.computerexchangeltd.com
Depot America, Inc.
Farmingdale, NJ
Tel: 800-648-6833 or 732-919-0209
http://www.depot-america.com/
Image1 Products, Inc.
Plano, TX 75074
Tel: 866-846-2431
http://www.image1products.com
Laser Pros International
Rhinelander, WI
Tel: 888-558-5277 or 715-369-5995
http://www.LaserPros.com
Masterworks International Inc.
Houston, TX
Tel: 800-695-2282
Fax: 713-896-0885
[email protected]
http://www.mwintl.com
Parts Now!
Middleton, WI
Tel: 1-800-886-6688 or 608-276-8688
http://www.partsnow.com
System Design Advantage LLC
Bloomington, MN
Tel: 1-800-947-0007
http://www.sdallc.com
TSAworld, Inc.
Norcross, GA
Tel: 800-633-6626 or 770-417-2323
http://www.tsaworld.com
Vance Baldwin Electronics
Fort Lauderdale, FL
Tel: 954-723-9191
http://www.vancebaldwin.com
Feb 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
How do we clear the cartrige to install first ink
Could you be more specific? Are you talking about removing an ink cartridge on an HP printer? If so, for most models, you press down on the colored ink holder from above to release the latch. Pull forward on the latch to disengage the arm completely. Then, pull the cartridge out.
Jan 11, 2008 | Computers & Internet
Lexmark X7170 All-In-One InkJet Printer Logo
236 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
