Question about magicJack Plus Pc To Phone Adapter
I moved. magic jack says no line when hooked back up
When hooking magicjack back up after moving on the phone it says no line. there is blue light flashing with the plug in adapt
Katlin Donnelly
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
  • Is everything turned on?
  • Is the blue light, inside your Magic Jack dongle, on? (Note that the Magic Jack Plus should have a flashing red and green led as well.) If you use the older model you might need to connect it through a powered hub to ensure the device receives enough power to operate properly?
  • If this is a new installation, is your internet service and computer capable of handling the requirements placed upon them by Magic Jack?
  • Do all your connecting cables appear to be firmly attached?
  • Are you watching Netflix, downloading or streaming files at the same time you are attempting to place a call?
  • If you are using the Magic Jack Plus, does the system report Error 3002?
Next, you should ask yourself what recent changes you have made to the computer/Magic Jack software? What recent upgrades have you performed to your hardware? Could this have effected the performance of your Magic Jack?
If your difficulties persist, it is time to divide and conquer. Google a 'you tube' link and watch the video. If you cannot connect to the internet, consult your internet provider for assistance. If the video is choppy, the internet connection might be too slow or bogged down. Perhaps your computer is too slow or requires maintenance. If you cannot hear sound, you might be experiencing problems with your soundcard or sound drivers. You should check Control Panel/Sound and ensure that 'USB internet phone by Tigerjet' is installed.
If the video ran correctly, the next step would be to test your handset and phone cord at another location.
If you prove the handset/phone cord to be correct, you have pinpointed your fault to either the Magic Jack or its software. Contact online support for Magic Jack.
Posted on Oct 13, 2014
My magic jack phone stopped ringing and the handset says no line
It sounds like the magic jack is not getting power. Is it plugged into the computer, or a wall outlet? Is the blue light on?
If it is plugged into a computer then unplug the Magic Jack and reboot the computer wait until it reloads and then plug the Magic Jack into a different USB port.
If it is plugged into the wall, Then unplug it for 5 min and then plug it back in.
If it doesn't come up and it is still covered by Magic Jack open up a chat with them at the link here. http://www.magicjack.com/contact.html
Sep 17, 2017 | Lands Phones
My magic jack plus will not work and I am wondering if the electrical connector is bad.
Go to the magic jack website and update your adapter. Also try different USB ports and reboot your computer with magic jack connected. If the computer does not recognize the adapter, try disconnectin and reconnecting into different ports. There is a update option on magic jack website and tech support as well.
Nov 04, 2014 | magicJack PLUS VOIP Phone Adapter
Why won't my magic jack work plugged into the wall outlet?
Magicjack uses the internet. It has to be hooked up to a computer using the internet. Its just skype for regular phones. Skype is free. magicjack cost 20 bucks. its a scam
Oct 27, 2014 | Cell Phones
Magicjack phone
Have you tried a new telephone cables going to the magic jack? That would be the first place that I would start.
Can you hook up a telephone to the existing line that's plugged into the magic jack then see if the noise occurs. If yes, then replace the cable. If no, replace the magic jack module.
Jan 22, 2014 | Computers & Internet
Magicjack problems
Phone is not workin...not ringing on ether end goes straight toice mail...
Dec 09, 2013 | Android Apps
Fax magicjack
  1. Operating Systems
    • As of 2010, the Magic Jack works well with Windows XP and Vista machines. Windows 7 has reported problems listed on their Microsoft Answers forum.
    Do Not Support
    • According to the Magic Jack company website they "...do not officially support using faxing with Magic Jack."
    Testing the Fax
    • Test your fax machine with Magic Jack by turning off the error correction on the machine and using the slowest speed available. If successful at that speed, increase the speed and check if it continues to work.
Read more: Does Magic Jack Support Faxing? ' eHow.com http://www.ehow.com/facts_7148239_magic-jack-support-faxing_.html#ixzz1tntAK093
May 02, 2012 | magicjack.com
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
magicJack Plus Pc To Phone Adapter Logo
552 people viewed this question
Top magicJack Cell Phones Experts
gaucherre
stargajzer
Are you a magicJack Cell Phone Expert? Answer questions, earn points and help others
