Repair guide
SOURCE: Fisher and Paykel GWL 11
Hi just read your posting.Try this,Put a couple of books under each foot of the machine high enough so you can look under the machine at the pump.Now select a spin mode and push the start button.Does the pump turn on its own?Where is your machine draining the water to,Is it into the laundry sink or some place else.Please reply with this additional information and this will help me in diagnosing this fault for you.Looking forward to your reply.
SOURCE: GWL-11 Fisher Paykel wont turn on and water on the floor
Look at my issue "eco smart won't drain, smells hot". Mine is top load.
If you see puddle on floor and eventually won't run at all and smell electric burn motor, it could be same issue I had.
Unplug washer. Tip washer back. If you see water dripping through the black motor area, you need to remove the black motor and the white plastic unit above it. Look for a white plastic clip that is attached to bottom of washing machine. Push that clip with your finger and twist the whole plastic unit/black motor. It all comes off in one piece.
Look on side of this unit and you will see 120V or 240V. Mine is GWL10US and is older model. Was told by repairman that new units use 120V. That is what you need to order. It comes as one piece and you just twist it back on. I had done most of this. Repairman came and 5 seconds cost me $65.
SOURCE: fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
SOURCE: when the washer (fisher & paykel gwl 11) goes into
Try unplugging the washer to reboot the curciut board. Leave unplugged for 5 min. Then replug and select only one setting. Multiple setting selected in a short period on time will confuse the little brain in the board. Reboot to fix. Be patient!
SOURCE: Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
