Question about Summit Refrigeration FFBF245SS - Counter Depth Refrigerator Freezer, A
<!-- from fixya rte -->Ice buildup summit freezer - Summit Refrigeration FFBF245SS - Counter Depth Refrigerator Freezer, A
Robin low
  • 28 Answers
Check if fan is working by pressin the door switch, or if you have exceptional high load recently. Remove everything off the unit overnight before you turn it back on again..
Posted on Nov 16, 2014
Not freezing enough
You might have ice building up on your evaporator coil. That ice serves as an insulator and prevents the internal freezer temps from going down to design parameters. The ice buildup is caused by the defrost mechanism not working - check the timer or the defrost heating element.
Jan 07, 2014 | Summit 12.6 Cu. Ft. Frost Free...
Ice maker quit making ice
Does the food in the freezer freeze solid? Do you see any ice buildup on the back wall?
Nov 10, 2012 | Frigidaire FFHT2126LW 30" 20.6 cu. ft. Top...
Early harvest no ice or thin ice
There is an adjustable potentiometer in the pcb section. Adjust it to give a thicker cube. Also check water pump and clean any scale buildup from the sprayplate. If all else ok and still no ice suspect evaporator sensor.
Aug 06, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Ice buildup in bottom
maybe your freezer has over charge causing to ice in the bottom or bubble stock up in the tube causing not to circulate the freon gas.
Jun 19, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
FRS6HR5HSB6 model frigidaire side by side fan making noise. Ice is building up around fan. What is causing ice buildup
the defrost circuit has a problem, allowing the frost/ice buildup..
remove the shelves, and back lower cover in the rear of the freezer to expose the evaporator coil, defrost heater, and defrost thermostat.
the defost heater should have continuity through it and the defrost thermostat will have continuity when frozen but test open when warmed.. if either bad replace.
if both test good look for bad connections in the freezer compartment wiring, and moly connectors otherwise the temperature controls are bad and it is an electronic assembly that incorporates the temperature controls with the deforst timer controls..
hope this helps,
best of luck,
ttfn
Nov 03, 2009 | Frigidaire Freezers
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
Roper--ice buildup on one freezer shelf
The reason for ice buildup is an air leak. Recheck all around the gasket by taking a dollar bill and closing the door on it and pulling it out. If you don't have resistance, you found your leak. Heat that area with a blow dryer to relax the gasket and close the door to let the magnet and seal set. Also, rub some vasoline on the hinge side gasket to keep it from dragging.
Dec 07, 2007 | Freezers
Summit Refrigeration FFBF245SS - Counter Depth Refrigerator Freezer, A Logo
185 people viewed this question
Top Summit Refrigeration Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Summit Refrigeration Freezer Expert? Answer questions, earn points and help others
