Question about Samson SX1200 Amplifier
Samson SX1200 - Protect light on. No blown output transistors.
Both chanwnels appear to be good. ie. No blown output transistors, no speaker circuit shorts and nothing gets hot. Anyone have a schematic for this amp? Extensive searches have yielded no results for a schematic.
Posted by Chris Worley on
Grubhead
  • Samson Master
  • 5,700 Answers
Have you checked the power supply section? Also look out for any IC's in the amp stages. They can go causing that kind of fault.
Posted on Oct 17, 2014
5 Related Answers
Anonymous
  • 236 Answers
SOURCE: Samson Servo 170 protection circuit problem!
my friend resistors and diodes don't just go off your circuit without a real problem. those parts gave up because of shortage on your power section, i suggest that you check your power transistros first along with the diodes and resistors.
noisy transformers... hmmmm why is that making sound? the solution there is to dip the power transformer to a thick shellac varnish let it there for let's say an hour then let it dry for a day. then place it back in your unit and see if still sounds
Posted on Aug 13, 2008
Anonymous
  • 73 Answers
SOURCE: Can I use my amp with PA speakers?
Yes, but stay within the "ohms" limit of the amp.(probably 4 ohm or greater)
Paul
Posted on Jun 13, 2009
bbl242003
Bruce lee
  • 1637 Answers
SOURCE: i am trying to find schematics for the samson 120
Here is a direct page to your needed information http://www.samsontech.com/products/productpage.cfm?prodID=1821
Posted on Jan 30, 2011
Ironfist109
Iron
  • 3018 Answers
SOURCE: one side of the amp
Either the channel on your radio is not working. Or the AV cord you are using is not working on one side (reverse the cord and plug it in the opposite you are using now. If it still only works on the one side your cord is good.) Or the final transistor for the channel on that amp might have blown. You could also have a cold soldier joint on or otherwise faulty jack plug. Let me know if this helps you find the issue.
Posted on Mar 07, 2011
palaboy
Rommel Cana
  • 5807 Answers
SOURCE: My speakers stopped working
Heating of the power transistor
can be one of the causes.
you may have to take out the complimentary pairs to check.
The pair may take out the drivers and some components along with it.
These may take some time, (troubleshooting)
But have a tech to guide you, if you need to DIY.
Good luck, let us know what you find or needs further assistance.
Posted on Oct 05, 2012
Channel A on my PMP 1280s is blown
This website appears to have diagram for it. You will have to register to log in. http://elektrotanya.com/?q=hu/content/how-change-site-language-english
May of been some other component burnt out. Only way is by test meter and testing. Quite possible transistor burnt out.
You should be able to test it in circuit for Short circuits.
If output transistors faulty make sure you check driver transistors as well. Hope some of that helps.
Nov 19, 2013 | Audio Players & Recorders
One side of the amp works but the other side doesnt drow signal of a samson sx1200
Mar 07, 2011 | Samson SX1200 Amplifier
When i switch on my samsung HT-Z110 the word hello appears then protect thenit turned off!
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Nov 29, 2009 | Samsung HT-DB600 System
I have blown the protection circuit on my yamaha rx 600d amp anyone with a clue whats needed to fix?
Hi friend,when something goes wrong in the output of the amplifier the protection circuit take place to prevent further damage could cause by DC power such as speakers or other related circuits...I think in your situation either one or both output amp stage have blown,then the protection cct turned on (not blown protection circuit!?). If so you have to check all the output transistors for short cct, if shorted you must also check all the DC bias cct nearby such as small transistors,resistors...If you are not familar with amplifier it better to find a tech as all amplifiers need a very precide repair technic , If the DC BIAS were wrong , when you turn on the power it will blow straight away! All times and cost will be waisted!
GOOD LUCK!
Tan Ta
Nov 23, 2009 | Yamaha Audio Players & Recorders
Noisy left hand power output stage. Noisy transistor? No circuit diagram.
If the speaker is not blown, there must be an output capacitor. If no output capacitor, and you have a blown transistor the speaker will blow from DC current. You can further check the transistors with a multimeter. A transistor looks like 2 diodes and you should be abobe to test with a mulimenter like a diode test.
May 12, 2009 | Audio Players & Recorders
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
Jan 01, 2009 | Rockford Fosgate Punch 401S Car Audio...
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
Dec 31, 2008 | Blaupunkt PCA460 Car Audio Amplifier
I have an audiobahn A8000t amp with the protection light on
Note:
Dec 30, 2008 | AudioBahn A8000T Car Audio Amplifier
Samson SX1200 Amplifier Logo
319 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
