Question about Motorola Mobility Universal Bluetooth Headset H500 - Pink Headset
<!-- from fixya rte -->HOW TO CHANGE BATTERY HEADSET H500 - Motorola Mobility Universal Bluetooth Headset H500 - Pink Headset
Danny Boy
    New Friend:
  • 18 Answers
Why do you think you need to replace the battery? A common sign that your Motorola Bluetooth headset needs a new battery is when you repeatedly hear five quick high tones in successive, one-minute intervals. Another symptom of a low or dead battery is when you try to scroll to Power and your headset doesn't come on. The Motorola H500 headset has a long battery life, but the battery eventually will go bad. Unfortunately, the battery is integrated as part of the headset's circuitry and should not be replaced by its user. Motorola strongly advises against trying to change the battery. Attempting to replace the battery voids the headset's warranty. By sending the headset to Motorola for repair, you can have a new battery installed without the risk of damage to your equipment.
But you can try the following at your own risk:
Locate the battery door at the rear of the headset and open it.
Remove the old battery. Install a new battery to match the plus and minus illustrations on the battery compartment. Shut the battery door back in place.
Select "Menu" on your phone. Select "Settings."
Select "Connection," "Bluetooth Link," and "Setup."
Select "Power." Select "Change."
Select "On," and then press "Select."
Press the "Call" button and hold it down. Release it when the LED light blinks.
Posted on Oct 13, 2014
HOW BATTERY TO CHANGE ON A H500 HEADSET?
Hi Anonymous,
If you are experiencing problems with the battery of your headset, the best is to get in touch with our support team, you can do that following this link: http://bit.ly/ContactUs-Locate
Regards,
Gaby
Motorola Mobility
Oct 11, 2014 | Motorola Mobility Universal Bluetooth...
Need to know the part number for the battery in the Motorola H500
The manufacturer part number 89127J for this headset is, and the battery it takes is 140 mAh Battery
Jul 28, 2010 | Motorola Mobility H500 Wireless Headset
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
Motorola H500 Headset Problem
TRhe pair code for my motorola headset is 0000 (that's zero zero zero zero)
Oct 16, 2008 | Motorola Mobility H500 Headset
H500 soft persistent beeping
this sound is the sound of count down from going from a standbye mode to shutting off itself to conserve battery thats all this is
cant stop it unfortunatly its built in feature
Jun 04, 2008 | Motorola Mobility H500 Wireless Headset
Battery replacement
Oh, I found it!
What comes off is the T-shaped chrome piece on the topside. To pry it off, start at the blunter end of the H500, on either side of the USB port. And note that this chrome piece is just a veneer, sitting on top of the black (in my case) plastic housing.
This web page shows and discusses the disassembly process, on the way to reusing the H500 innards for something else:
http://badacetechshow.com/BT%20Hat%20Pg.2.html
See ya...
-- Mark
Nov 28, 2007 | Motorola Mobility H500 Wireless Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
H500 bluetooth headset
Turn down the volume on the PHONE, not the headset. Motorola 325i w/ H500. Again, turn down the volume on the PHONE, not the headset. In my case almost all the way down.
Nov 15, 2006 | Motorola Mobility H500 Wireless Headset
Radio Communications Logo
727 people viewed this question
Top Motorola Mobility Radio Communications Experts
JonSnell Electronic
JonSnell Electronic
George Scott
George Scott
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
