My phones text settings seemed to have been set with the "group conversation by default" clicked on, which I did not do. Could that have been used by someone to also send my text messages to their phones as well without me knowing it? What does that setting mean? Thanks, Robert
I get this behaviour in email clients from time to time as well. It's usually due to updating the client (email, messages, messenger, text, whatever) to the latest version. Various folks like MS and Google and others seem to think we all want our communications 'grouped' in some fashion, so every time they update, they give you their preferred setting, and you need to turn it off again. The setting is just a view (sometimes called a thread) of conversations between you and others. I prefer my texts grouped just by recipient/sender and chronologically.
If your phone was used to forward your texts to someone else they should show up in the 'sent' side of the list, or in your 'recent' messages. Unless they deleted them as they sent them.
I'd lean to app misbehaviour before conspiracy... and if you have texts you don't want seen, put a lock on the phone, delete messages as you send them, or don't send them in the first place ;-)
SOURCE: Phone Sending MMS Messages as Default
The phone allocates a certain amount of storage for messages on a whole. Even though there may still show space available for text messages, you have hit an invisible "limit" and the phone is now defaulting to MMS messages because there is "room" there. Delete a fair amount of messages and you should be able to start sending regular text's again.
SOURCE: gprs n wap settings
Wap/gprs settings are to be requested from your service provider. Call your service provider's customer care and ask them to send wap settings to your mobile phone or visit your provider's website and look for the wap settings.
The master reset code for Nokia 3110c is *#7780# or *#7370#
SOURCE: Frusteration with "Invalid multimedia settings" on a Nokia
Hey i had the same problem and found out how to fix it. If it sais "Invalid Multimedia settings. Check settings" then you have to follow these steps:
1. Go to message settings under messages at the main menu
2. Click Text messages
3. Go to Message center in use and select SMS settings
This is how i fixed my problem which was the same as alyluvsskitt's
If this works for you then have fun texting!!!!
SOURCE: how do i reset the settings so that the default message is SMS
Changing your text message
settings
Your KC550 message settings are predefined so that you can send messages immediately. If you would like to change the settings, you
can do this using the Settings options.
Press Menu, select Messaging, then choose
Settings and Text message. You can make
changes to:
Message types - Convert your text into
Voice, Fax, Paging, X.400, Email or ERMES.
Validity period - Choose how long your
message is stored at the message centre.
Delivery report - Choose to receive confi rmation that your message was
delivered. Reply charging - Choose to be billed for your message recipient’s reply. Message centre number - Enter the details
for your message centre. Character encoding - Choose how your
characters are encoded. This impacts the size of your message and therefore data charges. Send long text as - Choose whether to
send your message as SMS or MMS when you enter a text longer than 2 pages in the message field.
Bearer setting - Choose whether to send your messages via GSM or GPRS. Changing your multimedia message
settings Your KC550 message settings are predefi
can do so using the Settings options. Press Menu, select Messaging, then choose Settings and Multimedia message.
You can make changes to:
Slide duration - Choose how long your
slides appear on screen. Priority - Choose the priority level of your
multimedia message. Validity period - Choose how long your
message is stored at the message centre. Delivery report - Choose to allow and/or request a delivery report.
FOR MORE SEE USER MANUAL
good luck
