When we turn it on red flashing lights appear can u help.
Here's a cool solution
Yes! That worked for me too! Thanks.
Buy a ps3
That worked for me.
I got the three red flashing lights. so i just pulled out the power cord. turn it back on. and everything was fixed. the red lights havent given me a problem since
Unfortunately there is nothing that you can directly do to fix this problem without voiding your warranty,. This means that if you attempt to repair it and fail MS will not fix it for you.. The "Fix" posted by others SOMETIMES works, but NOT ALWAYS.
Pleae be careful with your expesive gear!
You have a hardware failure. Microsoft will repair your unit for you under warranty / recall.
http://support.microsoft.com/kb/907534
Sorry to be the bearer of bad news.
If my solution was helpful, please vote for me!
SOURCE: xbox 360 not turning on, just red flash
It seems the power supply of your console has gone bad. Kindly have a local cartified technician check your Xbox ASAP.
SOURCE: The xbox 360 red light flash
turn it on and wrap it with 2 towels for 20 minutes(the idea is to overheat it), then unrap the towels and let it cool down for 20 minutes. Then, walla it works.
SOURCE: xbox 360 1 red light
The cause of E-74 with one red light Error might be overheating of your console and for
avoiding such error in future you need to put your machine at an open
space. Ensure that it is placed near the window or you can also make
some external arrangement for cooling of console such as cooling the
machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either
you can send your Xbox to Microsoft (Please note that microsoft is no
longer providing extended warranty for E74 with one red light Error) and wait for 3-4
weeks. If you don't want to wait for a month, you can also fix E74 with one red light
problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
