Question about Life Fitness Exercise & Fitness
How do I set the steps
How do you figure out the step setting so I get the correct amount of steps on my pedometer?
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: My Omron Walking Style 1 pedometer is not recording all steps.
OK I couldn't find the owners manual for the original posters unit however I did write to the manufacturer so I will keep you updated on that. So basic pedometer trouble shooting. If you replaced the batteries you have to reset all your settings including your stride length. make sure the unit is not hanging off where you click it as irregualr movements will mess up the accuracy. also ensure the unit is upright at all times. Also make sure you are not shuffling or wearing sandals as that will mess up the stride count as well Here is the manual for the HJ-112 model http://www.omronhealthcare.com/img/shop/hj-112---2005-112inst-rev-d.pdfll.
Posted on Apr 24, 2009
6ylucy
Dick Snider
  • 742 Answers
SOURCE: Lost instrutionspedomterfmradio model HE9965
ask at manualfox.com
they will get it for you
Posted on Jan 15, 2010
Anonymous
  • 21 Answers
SOURCE: If I walk 26 sq
you cant walk in square feet as this is an area.
you walk in linear feet. a straight line.
if you walk 26 linear feet in 10 strides then your stride length is 2.6 feet or 2 and a half feet per step.
Posted on Oct 13, 2010
tigagsk
SOURCE: I cannot get my pedometer to count steps. I was
I cannot get my pedometer to count steps. I was able to set up the pedometer, I can work the stopwatch, but cannot get it to start counting steps.
Posted on Jan 22, 2011
6ylucy
Dick Snider
  • 742 Answers
SOURCE: I have a Sportline pedometer
Get it here (link is verified)
Posted on Jul 26, 2012
I am a 77 year old Canadian, hard of hearing so am handicapped to use a phone. In setting my 4202 pedometer I was confused about setting a goal.
Sir,
if you have a teenage neighbor, ask them to help you by reading the instructions book, figure out how to set it as you want it, and then write down instructions you can follow for you.
teens are usually very quick to figure out things like that.
Mar 24, 2018 | Cameras
How do I reset the time?
How to Configure Your Omron HJ-303 Pedometer
www.walking4fun.com/.../pedometers/...pedometer/how-to-configure.ht...
When your pedometer first comes out of the box, you'll need to configure it. When youchange the battery, you'll have to reset the time on your pedometer, but the ...
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic Institutionyour pedometer and walk your way to better health. Pedometer Setup ... down theRESET button. Additional ... you'll track steps, time, and miles throughout your daily routine. And, in ... Do the math: 20 divided by the number of steps equals.
How to Reset an Omron Walking Style Pedometer ...
www.livestrong.com > Sports and Fitness
Oct 28, 2015 - Your Omron pedometer is a fitness accessory used to provide a great amount of ... session, including steps taken, time walked, distance traveled and calories burned. ... Do not use the end of a pencil to perform a system reset.
Dec 14, 2015 | Exercise & Fitness
What is the formula to figure out the pace
(I got this from http://www.livestrong.com/article/93695-set-up-omron-pedometer/)
Step 1
Pace out an area that's long enough for you to take 10 normal steps, in your natural stride, without having to turn to one side or the other. Place a piece of tape at one end of this distance, then stand with your toes flush with the edge of the tape.
Step 2
Carry another piece of tape with you as you walk straight ahead, taking 10 steps (5 with your left foot, 5 with the right). Stop at the end of the tenth step and place the tape flush with the toes of your leading foot.
Step 3
Measure the distance from one piece of tape to the other, in inches, with a measuring tape. Divide this distance by 10 to get your average stride length. If, for example, you walked 290 inches in 10 strides, your average stride length will be 290 / 10 = 29 inches.
Read more: http://www.livestrong.com/article/93695-set-up-omron-pedometer/#ixzz1uuGDz1tt
Nov 13, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
Oct 06, 2010 | VIA Balance 50003 Via Step Pedometer...
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    How do you work the pedometer
    Switch on, set up the timeframe you want it to record your steps, press start and have it in your pocket on your belt, when you walk. The motion sensors will detect the amount of steps you take within a given time period, or if you have it on all day, it will take your whole day's walking steps.
    Vote for me if this helps thanks.
    Jun 28, 2010 | Sportline 345 Electronic Pedometer
    Reebok B 2 pedometer
    1. Reset pedometer by pressing the reset button.
    2. Find a long open place and take 20 steps with the pedometer
    closed.
    3. Check the number of steps the pedometer counted. It should be
    between 19 and 21 steps.
    4. If the count was not right, try to move the pedometer forward
    (toward your belly button) or back (toward your hip) on your
    waist.
    5. Repeat this until you get the best count of your steps.
    6. Once found, place your pedometer in this spot each day.
    Apr 24, 2009 | RTO Reebok CS-1 Pedometer
    I am having problems with my Pedometer. What should I do?
    Review the following questions for common pedometer troubleshooting: a) Where are you wearing the pedometer? Make sure you are wearing your pedometer correctly by following these steps: * Clip your pedometer to your waistband or belt, directly above your knee. * Be sure your pedometer is perpendicular to the ground, not angled or dangling from your clothing. * Do not wear the pedometer on your shoe, sock, pocket or wrist. It will not provide an accurate reading. * Test the pedometer for accuracy by setting the step counter to zero and walking 50 steps. Check the display. If the reading is between 45-55, your step counter is functioning properly. If it reads more or less, reposition the counter on your waist and check again. * Your pedometer may give inaccurate results if you have had recent surgery or knee, leg, or foot problems. You may be favoring a leg or foot while walking. b)My pedometer has a clicking or loose part sound? Is it broken? No, a clicking or loose part sound is not an indicator of a broken pedometer. Every pedometer has an arm or pendulum inside of it. This is what counts the steps. The clicking noise that can be heard when the pedometer is shaken (or when you are walking) is the pendulum. c)The reset button will not work. The pendulum inside the pedometer is linked to the step counting device. The pendulum may become immobile from time to time, and this can prevent the reset button on the step counter from doing its job. If pressing the reset button a few times does not clear the display, here is what you can do to release the pendulum: * Give the pedometer a few gentle shakes while keeping the reset button held down. This un-sticks the pendulum. * Release the button. If the display has not cleared, press and release the button one more time. * If the display does not reset after trying this once or twice, call Customer Service.
    Dec 01, 2008 | Gaiam Walking Fit Kit Pedometer...
    Exercise & Fitness Logo
    53 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Vincent G
    Vincent G
    Thomas Perkins
    Thomas Perkins
    gbob59
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
